Here is a simple app that puts your thermostat in AWAY or HOME based on motion sensors and time delays.
Thanks to @copyninja for writting the iComfort app, and to @AaronZON who’s work this app is based on.
* Put thermostat in away or home mode based on motion and time delay.
* Written by Tuffcalc
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Thermostat (Away/Present on Motion)",
namespace: "tuffcalc",
author: "tuffcalc",
description: "Thermostat (Away/Present on Motion)",
category: "",
iconUrl: "http://www.bayareaheatingandcooling.com/wp-content/uploads/2014/01/thermostat-icon-150x150.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Select Motion Sensor(s) you want to use") {
input "motions", "capability.motionSensor", title: "Motion Detector", required: true, multiple: true
section("Select Thermostat you want to use") {
input "thermostat", "capability.thermostat", title: "Thermostat", required: false, multiple: true
input "DelayMinStr", "number", title: "Turn on AWAY mode after how many minutes?", required: true,
defaultValue: "120"
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
log.debug "Initialize... starting app and setting mode as HOME."
state.DelayMin = DelayMinStr
state.Home=true
thermostat?.present()
subscribe(motions, "motion.active", handleMotionEvent)
subscribe(motions, "motion.inactive", handleEndMotionEvent)
def handleMotionEvent(evt) {
log.debug "Motion detected."
unschedule(putAwayMode)
if (state.Home) {
log.debug "Thermostat already in HOME mode (do nothing)."
else {
state.Home=true
log.debug "Putting thermostat in HOME mode."
def handleEndMotionEvent(evt) {
log.debug "Motion stopped."
if (state.Home) {
runIn((state.DelayMin*60), putAwayMode)
def putAwayMode() {
log.debug "Putting thermostat in AWAY mode."
thermostat?.away()
state.Home=false
* Put thermostat in away or home mode based on motion sensor and/or contact sensor
definition(
name: "Thermostat (Away/Present on Motion or Contact)",
author: "tuffcalc",
description: "Thermostat (Away/Present on Motion or Contact)",
category: "",
preferences {
input "motions", "capability.motionSensor", title: "Motion Detector", required: false, multiple: true
section("Select Contact Sensor(s) you want to use") {
input "contacts", "capability.contactSensor", title: "Contact Sensor", required: false, multiple: true
input "thermostat", "capability.thermostat", title: "Thermostat", required: true, multiple: true
defaultValue: "120"
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
log.debug "Initialize..."
state.HomeMotion=true
state.HomeContactOpen=false
subscribe(contacts, "contact.open", ContactOpen)
subscribe(contacts, "contact.closed", ContactClosed)
// contact closed - start
def ContactClosed(evt) {
log.debug "Contact is closed."
log.debug "Putting thermostat in HOME mode because of Contact."
// contact closed - end
// contact open - start
def ContactOpen(evt) {
log.debug "Door or Window is Open."
log.debug "Putting thermostat in AWAY mode because of Contact."
thermostat?.away()
state.HomeContactOpen=true
// contact open - end
if (state.HomeContactOpen) {
log.debug "Thermostat already in AWAY mode due to CONTACT (do nothing)."
else if (state.HomeMotion) {
log.debug "Thermostat already in HOME mode due to MOTION (do nothing)."
else {
log.debug "Putting thermostat in HOME mode because of Motion."
log.debug "Start countdown timer to AWAY mode."
def putAwayMode() {
log.debug "Putting thermostat in AWAY mode because of Motion delay."
thermostat?.away()
state.HomeMotion=false
I believe all of this (the app and your question about only doing it from 9to 5) can be done with the existing “Hello Home” functionality of SmartThings.
Thanks! this is just what I was looking for… will see how it works out.
My Nest is in a hallway that only will sense me when I go to the bathroom basically. I have a motion sensor in my living room so this sounds ideal for me. Would also love to have the nest Temperature be based on my temperature sensor in my living room, or bed room, or average of the two. that’s for another day i suppose.
