I’m trying allow user input in preferences define the the value of scaledConfigurationValue which if you look below has a value of 1.
def configure() {
//send no-motion report 60 seconds after motion stops
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 2, scaledConfigurationValue: 1).format()
slagle
(Tim Slagle)
2
@Debosmebo I edited your post to properly display the code block.
Now for an answer:
You should be able to do something like this.
preferences {
input "configValue", "number", title: "Temperature Offset", description: "This would be the config value for the scale", displayDuringSetup: false
def configure() {
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 2, scaledConfigurationValue: configValue).format()
