Set attribute on simulated Device?
How could I set an attribute on a simulated device? I would like a SmartApp to set a simulated motionSensor to active or inactive so I could use that simulated motionSensor in the SHM app.
You might take a look at The code for Mike Maxwell’s zone manager. He takes multiple real sensors and associate them with a single virtual zone sensor and then turns that on or off as the other sensors trigger. :sunglasses:
Yes, you can set the attribute in a simulated sensor. I (and I’m sure others) do this to create a delayed entry with the SHM.
I use WebCoRE to do this but there are certainly other options.
Thanks, this will help I think.
