st.utils.screaming_snake_case("am not")
returns
AM NOT
should it not return
AM_NOT
Similarly
st.utils.pascal_case("am not")
returns
Am Not
AmNot
returns
AM NOT
AM_NOT
Similarly
returns
Am Not
AmNot
Thank you for sharing your results. I’ll look into it and create a report if necessary.
I’ll keep you updated.
Following up on this case, the one I also had issues with is this one, pascal_case works fine for me:
local util = require "st.utils"
local snakeCase = util.screaming_snake_case("I am not")
print("snakeCase "..snakeCase)
local pascal = util.pascal_case("I am not")
print("pascal "..pascal)
local camel = util.camel_case("I am not")
print("camel "..camel)
So, I’ll report that issue. Please, check again the pascal_case, are you importing correctly the st.utils?
You are correct, PascalCase is working correctly. I just looked at the wrong debug line.
