Samsung Smart Appliances + Matter?
Does anyone know if the Samsung branded appliances will be made available to other hubs via matter? I am talking about the standalone devices that do not connect to a ST hub (vacuums, ovens, washing machines, etc.). I recently saw some news about the new matter standard including a bunch of these and some companies like RoboRock are already planning to make their devices matter compatible via a firmware update. Samsung could fall behind quickly unless they follow suit.
This one is complicated, because matter is actually coordinating with a separate standard, which was in development for appliances. And Samsung is a founding member of that other standard, the Home Connectivity Alliance. They released the first version of their standard in August 2023.
Note that HCA’s goals are more modest than those of matter. For one thing, they are not requiring local integration, most of the smart appliances are currently communicating with a manufacturer cloud, and that will likely continue.
When you peel back the technical stuff, it looks somewhat similar to Ifttt. There will be predefined use cases, and “any app to any appliance“ will allow you to start with any of the members apps, and then add in appliances from the other members, but only for specific use cases.
The HCA Interface Specification 1.0 provides a framework for Cloud-to-Cloud (C2C)
interoperability and establishes a foundation of tangible benefits for consumers, starting with
legacy device integration and paving the way for energy savings in the future.
When HCA 1.0 interoperability enters the market, consumers will be able to control their smart
appliances, regardless of the manufacturer, through their existing appliance and HVAC apps.
No special hub is required, rather an update on a mobile app will enable most smart appliances
in the home, dependent on manufacturer rollout by product, geography and market.
So…l do think Samsung appliances will eventually show up in matter commissioning apps for those predefined functions, but I think everybody’s expectation is that these Device classes will continue to be cloud based. But it should mean they’ll show up in Apple home, for example, which would be cool. But I’m not expecting to see it before 2025 based on current announcements.
What we should see in 2024 is interoperability between a few of the major appliance manufacturers. Samsung and LG are already working on this. So my guess is that the primary benefit to SmartThings customers in 2024 will be for those who have LG appliances and want to bring them into the SmartThings app. Rather than the other way around. But we’ll see.
Oh, I should say that televisions and robot vacuums are an exception to this, because those device classes are included in matter itself. It’s the “white goods“ appliances: refrigerators, washing machines, dryers, etc. that are in the HCA but not in matter, most probably because of the local operation requirement.
This makes sense as most of the article was in regard to these two classes of appliances. I may have seen air purifiers in there as well. Not 100%
I found the original article again. It does mention refrigerators, dishwashers and washing machines for simple state triggers like cycle complete and temperature control. So if they add Matter 1.2 to their appliances (Matter over Wifi), then I think they should be available to other controllers.
As always, there are three sides to any matter decision
  1. the connectivity standards alliance, the independent third-party developing the matter standard, decides what it’s going to include.
  2. the individual voice assistant companies, decide what, if anything, in that standard they are going to implement and on what timeline. This is why Google assistant and Alexa, for example, might support different features of the same device connected over matter. Or not yet support an entire device class.
  3. the individual device manufacturers decide what, if anything, in the standard, they are going to implement and on what timeline for each individual model.
So… sure, the CSA has now added washing machines (but not dryers) to the matter standard for a few specific use cases, such as a notification that the wash is done.
But so far, no voice assistants have signed up to support those.
And unlike smart bulbs and smart plugs, and even a few vacuum cleaner models, no individual device manufacturers have yet announced a plan to add matter compatibility to their washers. (But several of the big ones have announced that they will meet the HCA standard I mentioned in a previous post.)
We’ll just have to wait and see what happens. :thinking:
I am currently looking at potentially getting both a Samsung ASHP heat pump and a Samsung AirCon system and less likely but possibly Samsung laundry (washer & dryer) and refrigeration. Various models could be added to Smartthings. In fact it seems Samsung despite selling off Smartthings to Aeotec are basing all their smart home solutions on building Smartthings hubs in to each device. (This is now practical due to Smartthings allowing multiple Smarthings hubs to be used together.)
CORRECTION: Samsung have not sold off Smartthings but have licensed Aeotec to make Smartthings Hubs.
Ignoring the illogic of selling off Smartthings and hence loosing control over it but limiting all their devices to using it, this still effectively means Samsung are operating a closed proprietary environment which is the entire antithesis of Matter which Samsung is a member of. Samsung/Smartthings does not officially support bridging from Smartthings to Matter - unlike Philips Hue.
I have seen mentions of possibly using either a Hubitat Elevation or Home Assistant linked to Smartthings and then use one of these to bridge out to Matter including the Smartthings devices.
If one has potentially multiple Smartthings hubs (built-in to Samsung appliances) and link these to either Hubitat Elevation or Home Assistant, which would be better for bridging the Samsung appliance to Matter?
you may want to edit that line. Samsung did not sell SmartThings to Aeotec. Aeotec is licensed to sell a stand-alone hub for Samsung SmartThings.
Hello,
It’s a very good idea to consider using a heat pump and air conditioning. It’s a very robust and reliable technology. If you already have Samsung appliances and electronics, don’t hesitate, like Samsung. smartthings has a very powerful rules engine, easy to use in the app, that will allow you to automate and make profitable your fully integrated Samsung system.
This technology has a future because, thanks to renewable energy, photovoltaics, wind power, and green H2, we’ll have cheaper electricity for everyone, even though the deniers want to trick us into continuing to use gas and oil. Don’t listen to them; they’re living fossils that haven’t managed to turn into gas, :rofl:
In Spain, where we’ve been suffering the effects of climate change for many years now, we have a lot of air conditioning installed to protect us.
I use three inverter Panasonic split units and two Daikin units, both of which are over 20 years old.
With Smart Things and five moes remotes with @otivax , hola Javi eres un crack, drivers and five sonoff th1 temperature sensors with my virtual thermostat in my Mc drivers, I’ve managed to automate my home’s heating and cooling. I’ve stopped using my oil boiler and saved more than €1,500 in energy in just one year.
Imagine what you can achieve with modern Samsung technology integrated into Smart Things.
Continue supporting those who believe in the ecological transition, which can save our planet; we have no other for our children.
Regards
EDIT:
Reading is voluntary and I only intend to share technology with social ideas.
I’m going to tell you in Spanish a true story, which illustrates how to elect good politics, who legislate sensible technological regulations that make technology useful to society as a whole and not just to a privileged few.
En los 2004-2008 vivía la sociedad occidental una bonanza económica con la burbuja inmobiliaria y las hipotecas baratas.
En España el gobierno social demócrata de Rodríguez Zapatero decidió crear un plan de futuro económico para España, el actual del ladrillo no podía durar toda la vida, se agotará.
Pensaron, ¿Qué necesitamos?, Energía barata y abundante para potenciar la industria y coger el relevo del ladrillo
No tenemos petróleo, ni gas, pero tenemos Sol y viento
Diseñaron un plan para instalar parques solares y eólicos impresionante.
¿Como vamos a financiarlo e instalarlo?: Tenemos que hacerlo atractivo para inversores de todo el mundo y a empresas que los instalen.
Idearon las “Primas a las energías renovables”: los inversores y empresas tienen que ganar dinero para que se interesen.
¿De donde sacamos el dinero de las primas?: Del recibo de la luz. Las empresas y usuarios españoles pagarán una tasa para conseguir su energía del futuro, que les dará bien estar.
El plan se cumplió, los inversores de y empresas de todo el mundo cumplieron su parte hasta que la crisis financiera mundial lo destrozó todo.
ºel gobierno socialdemócrata cayó y un gobierno de derechas con Mariano Rajoy llegó, le pusimos nosotros con nuestro voto.
Mas de 7 millones de españoles fueron al paro y sus empresas a la quiebra.
Europa nos rescató con un crédito de 40.000 millones de EUR, que aun estamos devolviendo, no fue un regalo de nadie, fue una ayuda bienvenida y necesaria.
Zapatero le dejo a Rajoy 70.000 millones de € en la hucha de las pensiones de todos los españoles, Rajoy lo gastó todo y jamás nos lo agradeció a los españoles
Los costes sociales fueron tremendos, subida de impuestos a la clase media y amnistía fiscal a los ricos para trajeran su dinero en paraísos fiscales a coste casi 0 e impunidad.
Recortes en servicios, sanidad, educación hizo que saliéramos a las calles a defendernos, juntos médicos, ingenieros, trabajadores de todos los sectores.
Los bancos, máximos responsables de la crisis financiera recibieron millones y millones de € públicos gratuitos para no ir a la quiebra .
El gobierno decidió incumplir el contrato de las primas a las renovables y nos metió en una guerra judicial mundial por parte de los inversores y empresas extranjeras, que aun estamos librando.
Su política energética fue instaurar el ¿impuesto al sol!. Los que quieran obtener energía del sol tendrán que pagar, no cobrar. ¡Que genios!. Todo se paró.
En 2018 volvió el gobierno progresista con Pedro Sanchez.
derogó el impuesto al sol y crearon un plan para relanzar la transición ecológica. El resultado lo ve el mundo entero; España creciendo más que nadie, energía barata y abundante y los españoles recobrando calidad de vida y derechos.
A la cabeza del plan Teresa Ribera ministra de transición ecologica, (dirigirá el plan) y Nadia Calviño(ministra de economía conseguirá financiación).
Maria Jesus Montero, ministra de Hacienda, gestionará ayudas directas, deducciones impuestos en instalaciones fotovoltaicas individuales 20% factura y sustitución de calderas de carbón y gasóleo 10% de facturas. y mucho más, ¡es ministra de hacienda!
Teresa hoy Vicepresidenta de la comisión europea y Nadia presidenta del Banco europeo de inversiones. Están allí para ayudar a Europa a crear un plan de futuro.
La financiación del plan son los Fondos europeos de recuperación, Next Generation.
Devolveremos estos fondos en forma de energía verde H2 para que Europa pueda abandonar el gas y relanzar su potente industria Europea, alemana y francesa, vitales.
Francia ha entendido a regañadientes que tiene que permitir el gaseoducto H2 verde hacia Europa.
Ahora en España tenemos energía verde de sobra, los centros de datos nos invaden, creando riqueza, pero consumen mucha agua para refrigeración, que no tenemos. Hay que buscar una solución.
El siguiente paso es instalar parques de baterías químicas ion LI o mejores Para robustecer nuestra red eléctrica y no desperdiciar los excedentes verdes y usarlos todo el día, generar H2 y dejar el gas. El dinero es limitado y hay que priorizar.
Ahora usamos baterías hidráulicas en nuestros pantanos. Durante la noche generamos electricidad con el agua y durante el día utilizamos la energía solar y eólica para remontar el agua al pantano previo y recargarlo a un coste casi 0. ¡Ingenioso!, pero no suficiente en el futuro.
Cuando Europa trabaja junta somos imparables y por eso quieren pararnos, ya sabéis quienes. Hay que defender Europa oriental para que siga en la unión europea.
Reino Unido, parte siempre protagonista del corazón e historia de Europa, consiguieron separarnos. Europa y Reino Unido nos necesitamos mutuamente.
Ahora estáis en buenas manos, con un país muy dividido y muchos problemas, darle tiempo para que encontréis el rumbo y seguir siendo un gran país en este mundo que tenemos que conservar para nuestros hijos.
Esto es un ejemplo de como la tecnología, la política y la ciencia pueden ayudar juntas a crear sociedades mas justas y solidarias.
Nunca dejéis de votar voluntariamente, en ese caso otro decidirá por ti.
