Hi, @timmo, I saw your comment here.
As mentioned in the announcement, if you re-paired some Zigbee devices, it shouldn’t have affected you and the devices re-paired should’ve stayed connected, this should be investigated further.
Can you provide support access to your account and the name of a device that you re-paired and went offline after the fix, please?
- Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM
- Enable support access to your account:
- Go to the SmartThings Web (my.smartthings.com)
- Log in to your Samsung Account
- Select Menu (⋮) and choose Settings
- Toggle on Account Data Access
- Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
