If you’re not seeing Intrusion Detection alerts on the Dashboard when the Alarm Status is in either Arm mode, that may be a question for ST support.
I use RM to set my mode and Alarm Status based on presence (and Arm(Stay) based on presence and bedroom door closing) and still get the Intrusion Detected messages.
Mode and Alarm Status are 2 separate items. Not everyone uses SHM (Smart Home Monitor) so they might not use the Alarm Status. The Alarm Status is just for notifications when something irregular occurs so that you can be aware of what’s going on when you’re away. It’s configurable, but has some flaws. Some people use Rule Machine instead by setting up rules for different modes that will alert them when things occur. Other people use Smart Alarm since it offers the ability to use a keypad with a delay
The Mode is generally used for Routines and, for apps like Rule Machine, a restriction to limit when certain rules will occur. The Mode can be used in SmartApps to alert you of something only if in a certain mode (some people only want to be notified that a window is left open for more than 5 minutes if they go into Away mode and leave the house, for example).
I do get the intrusion detection when I configure SHM but not when I set RM to monitor the same door. The trigger is setup to monitor in all modes and the SHM is set to Arm. Here are the screen shots
Perfect, your last sentence is what I was looking for
If only SHM is monitoring, I get Intrusion Detected and push, text notification
If only RM is monitoring, I only get push and/or text, no Dashboard alert.
So based on your example above re: “I use RM to set my mode and Alarm Status based on presence (and Arm(Stay) based on presence and bedroom door closing) and still get the Intrusion Detected messages.” I assume you are setting both RM and SHM
I wish! I’m still waiting for my hub to come back online since the outage. Smarthings reports all things are green but thats BD. Multiple people are still down, myself included.
Anyway thank you for the procedure. It will really help me out but time is of the essence in my case and this outage sucks.
I was wondering why you decided to do two rules if you mention you can do it in one. I don’t understand what you mean by smarthings issue.
bamarayne
349
It can be done with by feeding back on itself, essentially creating an infinite loop. But that is unstable by itself, and if you throw in the ST scheduler issues… Not a chance.
I’ve read @Rigging65’s post on creating a gradual dimmer using RM (here), and I get the gist. I have a couple of questions for the illuminati here about that:
I assume that, rather than using a delayed on/off with a virtual switch, you could instead use the “Evaluate Rules after Delay” action and use a recursive reference to do the looping, yes?
Has anybody figured out how to do this in the other direction (a la "“Gentle Wake Up”) with just one rule? I realize that it’s straightforward to do with two, but if it can be done with one, I would consider that a more elegant solution.
I was wondering if someone could help me. I successfully got my lamp to turn green when my garage door opens, however, I can’t get my actions for false to happen. Here is a screenshot:
I think you need a separate rule for “closing” to trigger the reciprocal action.
bamarayne
354
Go back into the rule and check everything to make sure the box is checked next to it. Sometimes the Android app will glitch and it shows your selections, but they affect actually checked.
I tried all of that. It’s funny because when I save the rule, the desired action takes effect if my garage door is closed. (RM fires the rule correctly when saving and my garage door is shut. It is recognizing that the rule is false when I save he rule.) but it won’t fire off my actions for false I close my garage door.
Hi Everyone - I am racking my brain trying to figure this out…not sure If I need two rules or can do it in one…
Scenario - When I let my dog out at night (Sunset to Sunrise), I want the spot lights to go on, then when I let her in, turn them off. I have a door sensor on the door that I’ll be using - So, I would like it to act like this:
Backdoor Contact Sensor = Open --> Lights come on
Backdoor Contact Sensor = Closed --> Lights stay on (Dog is still outside)
Backdoor Contact Sensor = Open --> Lights still on (Letting dog in)
Backdoor Contact Sensor = Closed --> Lights switch off
Thanks in advance for any help.
Mark
bamarayne
357
Hi Mark.
I just set this up and tested it. It works great!
butttt…
It will very easily get out of sync. Then you just have to open the door and close it again.
Conditions - backdoor open, lights off, lights on
rule - complex rule (backdoor open & lights off) OR (backdoor open & lights on)
actions for true - toggle light
actions for false - blank
Thank you - this will work…I was trying to get the lights to go off when I closed the door the second time, but this will work! I added the night condition - so the complex rule looks like this:
(Time Between Sunset and Sunrise AND (Back Door Open AND Spot Light Off) OR (Back Door Open AND Spot Lights On))
David is correct rule machine needs actions & reactions. So if you have a rule to open & do something you will also need a rule to close & do something. And everything can be done in one rule or conditional trigger I hope this helps explain it.
I am struggling with what rule machine can do for a fairly cool lighting idea I have.
I need functions rather than rules because i want to create a “rule” which, when called, evaluates some conditions and then if true, proceeds. But i do not want the rule to evaluate just whenever those conditions change. Only when directed.
Scenario: i have 2 RGBW lights and i have them associated to my family room home theater.
I have a goal of using them in 2 modes, colors on or colors off. This means that when a virtual switch “colors” is on, rules which would change their color based on harmony activity (virtual switches for netflix, playstation, cable, dvd, music) are evaluated and change colors. And when “colors” is off, rules which change their temp based on time of day are evaluated.
I have LED strips on the back of my TV. They turn certain colors for certain harmony activities that are actuated. Red for Phillies game. Blue for Villanova basketball game.I created a rule that this only happens after certain time of day. Sunset. If there is no harm any activity running they turn off. My rule says four instance, if virtual button pushed for Villanova game(harmony activity), then trigger TV lights blue.only if time between 4 PM and 11 PM.
