Hi Folks … I looked without any success for a reverse logic momentary button that is always on until you press it and then it is off briefly and then back on. I needed this because I need to tell Alexa to turn off my TV using a momentary button. Without this I have to tell it something that doesn’t sound like English like… “Alexa, turn on TV off” which is stupid. So I wrote this device type which simply reverses the logic of a virtual momentary button. Then I assign it to a Harmony action that turns all entertainment devices off. Here is the code for the device type. To use this just make a new device and assign this type, and then write your smart app referencing it. Don’t forget to add it to Alexa and do the Discover New Devices thing. Enjoy.
- Copyright 2015 SmartThings
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- Momentary Off Button
- modified Momentary Button Tile with reverse logic
- Author: Ken Washington - adapted from SmartThings
- Date: 2013-05-01
- Date: 2016-03-31
metadata {
definition (name: “Momentary Off Button”, namespace: “kewashi”, author: “Ken Washington”) {
capability “Actuator”
capability “Switch”
capability “Momentary”
capability “Sensor”
// simulator metadata
simulator {
// UI tile definitions
tiles {
standardTile(“switch”, “device.switch”, width: 2, height: 2, canChangeIcon: true) {
state “on”, label: ‘Push’, action: “momentary.push”, backgroundColor: “#53a7c0”
state “off”, label: ‘Push’, action: “momentary.push”, backgroundColor: “#ffffff”, nextState: “on”
main “switch”
details “switch”
def push() {
sendEvent(name: “switch”, value: “off”, isStateChange: true, display: false)
def i=1000
def y = 0
while(i) {
def x = 1.23 / 5.2
y = y+ x
i–
sendEvent(name: “switch”, value: “on”, isStateChange: true, display: false)
sendEvent(name: “momentary”, value: “pushed”, isStateChange: true)
def on() {
push()
def off() {
push()
