Rest services api
Need to if there are REST APIs documented.
If buy real devices how can I used REST apis to get the device info
http://docs.smartthings.com
But I need to run the code in their env using groovy.
Can I use any other technologies to get the info?
You would need a SmartApp running within the ST environment that would provide the endpoints with which your external technologies would interact.
How I get the smart things env in my server to do this?
The SmartApp would have to run in the ST cloud and create the endpoints. You could then query that.
Can I deploy the code in our server instead of their cloud Also any one has number for the questions session with Smart Things happening every Wednesday ?
@sxganapa You can host your code on your own server, but there is not a generalized API available, you have to make your own. The only thing that will reside on the SmartThings cloud is your API code. Take a look at the docs.
http://docs.smartthings.com/en/latest/smartapp-web-services-developers-guide/index.html
The link to the developer calls is here.
https://community.smartthings.com/c/groups-events/developer-discussion
