- on - Turns on the switch
- Required for the “Switch” capability
def on() {
if (switchDisabled) {
logDebug “switch disabled, doing nothing”
delayBetween([
formatCommand(zwave.switchBinaryV1.switchBinaryGet())
], 200)
} else {
logDebug “switching it on”
delayBetween([
formatCommand(zwave.switchBinaryV1.switchBinarySet(switchValue: 0xFF)),
], 200)
- off - Turns off the switch
def off() {
delayBetween([
], 200)
} else {
logDebug “switching it off”
delayBetween([
formatCommand(zwave.switchBinaryV1.switchBinarySet(switchValue: 0x00)),
], 200)
poll - Polls the device
Required for the “Polling” capability
def poll() {
logTrace “poll()”delayBetween([
formatCommand(zwave.switchBinaryV1.switchBinaryGet()),
formatCommand(zwave.meterV3.meterGet(scale: 0)), // energy kWh
formatCommand(zwave.meterV3.meterGet(scale: 1)), // energy kVAh
formatCommand(zwave.meterV3.meterGet(scale: 2)), // watts
formatCommand(zwave.meterV3.meterGet(scale: 4)), // volts
formatCommand(zwave.meterV3.meterGet(scale: 5)), // amps
], 200)
refresh - Refreshed values from the device
Required for the “Refresh” capability
def refresh() {
logInfo “refresh()”
updateDeviceInfo()sendEvent(name: “power”, value: “0”, displayed: true, unit: “W”)
sendEvent(name: “energy”, value: “0”, displayed: true, unit: “kWh”)
sendEvent(name: “amperage”, value: “0”, displayed: true, unit: “A”)
sendEvent(name: “voltage”, value: “0”, displayed: true, unit: “V”)sendEvent(name: “currentEnergyCostDay”, value: “0”, displayed: true)
sendEvent(name: “currentEnergyCostWeek”, value: “0”, displayed: true)
sendEvent(name: “currentEnergyCostMonth”, value: “0”, displayed: true)
sendEvent(name: “currentEnergyCostYear”, value: “0”, displayed: true)sendEvent(name: “cumulativeEnergyCostDay”, value: “0”, displayed: true)
sendEvent(name: “cumulativeEnergyCostWeek”, value: “0”, displayed: true)
sendEvent(name: “cumulativeEnergyCostMonth”, value: “0”, displayed: true)
sendEvent(name: “cumulativeEnergyCostYear”, value: “0”, displayed: true)delayBetween([
formatCommand(zwave.switchMultilevelV1.switchMultilevelGet()),
formatCommand(zwave.configurationV1.configurationGet(parameterNumber: 0x51)), // device state
formatCommand(zwave.configurationV1.configurationGet(parameterNumber: 0x53)), // night light RGB value
formatCommand(zwave.configurationV1.configurationGet(parameterNumber: 0x54)), // led brightness
], 200)
- reset - Resets the devices energy usage meter and attempt to reset device
- Required for the “Switch Level” capability
def setLevel(level) {
setBrightnessLevel(level)
Sets the color to the passed in maps values
Required for the “Color Control” capability
def setColor(colormap) {
logDebug " in setColor"if (colormap.hex == null && colormap.hue) {
def hexColor = colorUtil.hslToHex(colormap.hue, colormap.saturation)
logDebug " in setColor colormap = $hexColor"sendEvent(name: "color", value: hexColor) formatCommand(zwave.configurationV1.configurationSet(parameterNumber: 0x53, size: 3, configurationValue: colorUtil.hexToRgb(hexColor)))
} else {
logDebug " in setColor: hex = ${colormap.hex}"
sendEvent(name: “color”, value: colormap.hex)
def hexColorList = colorUtil.hexToRgb(colormap.hex)
formatCommand(zwave.configurationV1.configurationSet(parameterNumber: 0x53, size: 3, configurationValue: [hexColorList[0], hexColorList[1], hexColorList[2]]))
- Methods *
installed - Called when the device handling is being installed
def installed() {
logInfo “installed() called”if (state.deviceInfo == null) {
state.deviceInfo = [:]
state.deviceInfo[‘secureInclusion’] = false
}// Call a reset upon install to clear all values.
reset();updateDeviceInfo();
updated - Called when the preferences of the device type are changed
def updated() {
logInfo “updated()”updateStatus()
//updatePowerStatus(0)
response(configure())
Defined by the custom command “reset”
def reset() {
logInfo “reset()”
state.energyMeterRuntimeStart = now()def timeString = new Date().format(“MM-dd-yy h:mm a”, location.timeZone)
sendEvent(name: “resetDate”, value: "Since: "+timeString, unit: “”)delayBetween([
formatCommand(zwave.meterV3.meterReset()),
], 200)
def factoryReset() {
logDebug “factoryReset()”
formatCommand(zwave.configurationV1.configurationSet(parameterNumber: 0xFF, size: 4, scaledConfigurationValue: 1))
//factory reset
configure()
def getDeviceInfo() {
logDebug “getDeviceInfo()”
delayBetween([
formatCommand(zwave.versionV1.versionGet()),
formatCommand(zwave.firmwareUpdateMdV2.firmwareMdGet()),
//zwave.manufacturerSpecificV2.deviceSpecificGet().format(),
formatCommand(zwave.manufacturerSpecificV2.manufacturerSpecificGet())
], 200)
private updateStatus() {
def sinceTime = ‘’
if (state.energyMeterRuntimeStart != null) {
sinceTime = “${getBatteryRuntime()}”
} else {
sinceTime = now()
sendEvent(name: "statusText3", value: "Elasped Time since Reset: $sinceTime", displayed: false)
private updateDeviceInfo() {
logInfo “updateDeviceInfo()”
def buffer = "Get Device Info";
def newBuffer = null;
def switchStatus = "SWITCH ENABLED\n"
switchStatus = "SWITCH DISABLED\n"
if (state.deviceInfo['applicationVersion'] == null ||
state.deviceInfo['manufacturerName'] == null) {
getDeviceInfo()
} else {
newBuffer = "${switchStatus}"
if (state.deviceInfo['applicationVersion'] != null) {
if (newBuffer == null) {
newBuffer += "app Version: ${state.deviceInfo['applicationVersion']} Sub Version: ${state.deviceInfo['applicationSubVersion']}\n";
newBuffer += "zWaveLibrary Type: ${state.deviceInfo['zWaveLibraryType']}\n";
newBuffer += "zWaveProtocol Version: ${state.deviceInfo['zWaveProtocolVersion']} Sub Version: ${state.deviceInfo['zWaveProtocolSubVersion']}\n";
newBuffer += "secure inclusion: ${state.deviceInfo['secureInclusion'] || secureInclusionOverride}\n";
if (state.deviceInfo['manufacturerName'] != null) {
newBuffer += "manufacturer Name: ${state.deviceInfo['manufacturerName']}\n";
newBuffer += "manufacturer Id: ${state.deviceInfo['manufacturerId']}\n";
newBuffer += "product Id: ${state.deviceInfo['productId']} Type Id: ${state.deviceInfo['productTypeId']}\n";
newBuffer += "firmwareId: ${state.deviceInfo['firmwareId']} checksum: ${state.deviceInfo['checksum']}\n";
newBuffer = buffer
return sendEvent(name: "deviceInfo", value: "$newBuffer", displayed: false)
private getBatteryRuntime() {
def currentmillis = now() - state.energyMeterRuntimeStart
def days = 0
def hours = 0
def mins = 0
def secs = 0
secs = (currentmillis / 1000).toInteger()
mins = (secs / 60).toInteger()
hours = (mins / 60).toInteger()
days = (hours / 24).toInteger()
secs = (secs - (mins * 60)).toString().padLeft(2, ‘0’)
mins = (mins - (hours * 60)).toString().padLeft(2, ‘0’)
hours = (hours - (days * 24)).toString().padLeft(2, ‘0’)
if (days > 0) {
return "$days days and $hours:$mins:$secs"
} else {
return "$hours:$mins:$secs"
private getBatteryRuntimeInHours() {
def days = 0
def hours = 0
def mins = 0
def secs = 0
mins = (secs / 60)
hours = (mins / 60)
return hours
void logInfo(str) {
log.info str
void logWarn(str) {
log.warn str
void logError(str) {
log.error str
void logDebug(str) {
if (isLogLevelDebug) {
log.debug str
void logTrace(str) {
if (isLogLevelTrace) {
log.trace str
def nightLight() {
logDebug “in set nightlight mode”
sendEvent(name: “deviceMode”, value: “nightLight”, displayed: true)
setDeviceMode(2)
def energy() {
logDebug “in set energy mode”
sendEvent(name: “deviceMode”, value: “energy”, displayed: true)
setDeviceMode(0)
def momentary() {
logDebug “in momentary mode”
sendEvent(name: “deviceMode”, value: “momentary”, displayed: true)
setDeviceMode(1)
def setDeviceMode(mode) {
logTrace “set current mode to ‘$mode’”
formatCommand(zwave.configurationV1.configurationSet(parameterNumber: 0x51, size: 1, scaledConfigurationValue: mode))
def setBrightnessLevel(newLevel) {
logDebug “in set setlevel newlevel = ‘$newLevel’”
sendEvent(name: “brightnessLevel”, value: newLevel.toInteger(), displayed: true)
// There seems to have an error in the documentation where this config should be a size = 1
formatCommand(zwave.configurationV1.configurationSet(parameterNumber: 0x54, size: 3, configurationValue: [newLevel, newLevel, newLevel]))
def formatCommand(physicalgraph.zwave.Command cmd) {
if (isSecured()) {
logTrace “Formatting secured command: ${cmd}”
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
} else {
logTrace “Formatting unsecured command: ${cmd}”
cmd.format()
def isSecured() {
(state.deviceInfo && state.deviceInfo[‘secureInclusion’]) || secureInclusionOverride
def internalCreateEvent(event) {
if (forceStateChangeOnReport) {
event.isStateChange = true
return createEvent(event)
Here is the Settings Page:
