[REQUEST] APC Home Office SurgeArrest 6 Outlets 3 Smart Outlets Integration
I have an APC Home Office SurgeArrest 6 Outlets 3 Smart Outlets With 4 USB Ports 2 Smart Ports 120V which works perfectly with Amazon’s Alexa APP. But I’d like to see if it can be integrated into SmartThings in order to create complex routines via WebCORE.
Thanks in advance!
User Manual Link
As of late 2019, smartthings has made their API public, and it is now up to the individual device manufacturers to provide a smartthings integration if they choose to do so. So you should make the request of them.
https://smartthings.developer.samsung.com/
That said, if it works with Alexa you may be able to use Alexa routines as a partial integration if the smartthings/alexa integration works for you.
Here’s the thread on the integration:
New SmartThings Alexa skill (2020)
If someone is looking to build an integration, APC uses the Ayla Networks IoT SDK for these powerstrips. The API is open and documentation can be found at: https://developer.aylanetworks.com/apibrowser/swaggers/
I got GPT SOL 6.1 to write ESP32 firmware to act as a bridge to the SurgeArrest Strip, and it also wrote an Edge Driver to control it.
If anyone wants to integrate the APC SurgeArrest strip with SmartThings, you need an ESP32 as a bridge and can check out this solution here:
Project overview — features, requirements, and beginner setup instructions.
Firmware downloads — the beta release and installation files.
SmartThings driver installation — enroll the hub, then install APC SurgeArrest ESP Bridge.
