Hi everyone - using version 2.5.10. Thanks so much for programming this.
A few questions:
Can someone please explain the difference between device and structure polling? I get the device part (it will poll each nest protect for status - e.g., OK or alarming) - but what is the structure polling for?
For device polling, if it is set at 3 minutes, and a poll just completed, and then an alarm sounded - am I correct in thinking that smartthings will not know the nest is in an alarm state until the next poll (2 minutes and 59 seconds away)?
What does âonly update devices on new dataâ do? I have my device poll rate set at 3 minutes, location poll rate at two minutes, and âonly update devices on new dataâ set to on. I notice in the logs that I get updates that do not correspond with the 1 and 3 minute polling. Not clear why this is happening at odd times.
Iâm pretty sure everything is working fine, just trying to understand how this actually works under the hood.
It seems that I am not able to edit the dropdown for âCategoryâ under the Definition. My icon changes to a red circle with an line through it. And when I changed the category in the code (at line 27 to read category: âMy Appsâ,) it doesnât seem to have any affect as well.
Can someone explain what I may be doing incorrectly and how do I get the published app to show on my mobile device?
I donât see My Apps in the marketplace so I thought I needed to change the code because when I hover over the category dropdown it says âUpdate this value in the source codeâ. This is my first app so Iâm not sure if there was something I should have done previously to have the âMy Appsâ display on my iPhone.
So now I could have 2 issues. #1 I changed the Category in the source code. Should I change it back to the previous value? #2 I did a hard restart on the app and the hub and I still do not see âMy Appsâ in the Marketplace.
Thanks and any help for this newbie would be greatly appreciated!
I can restore it back to the original code. However, I still do not see the My Apps under either tab as I have checked both after restarting the hub and restarting the app.
Iâve installed, uninstalled, and reinstall, but Iâm still getting the same error âDevice handlers are likely missing or not publishedâ; please help.
