So what is the consensus on the most reliable z wave/zigbee motion sensor. I originally was going to use my existing alarm motion sensors, but they are RF and not wired so I cannot integrate them into my NODEMCU board like the rest of the alarm system.
Since these are for security I want something that is reliable with the least possible false positives. I know some of the detectors have temperature and other features, this would be welcomed but not at the cost of the motion reliability.
I own Go Control, Iris and Xiaomi motion sensors. Once connected, they have all been equally as reliable, But I’ve also never had any z-wave or zigbee mesh issues. This is most likely one of those YMMV sceanrios
From what I have been reading it seems alot of people are happy with the Iris. Range should not be an issue because I have z wave plus switches all over the house and the hub will be on the same floor as the motion detectors. Plus my house has a very open concept floor plan.
I like the EcoLink w/ Pet Immunity, so i don’t get false positives. I’ve used Iris, ST v1, ST v2, ST v3, Monoprice, Ecolink and the Ecolink seems to be the best w/ false positives when i have it w/ the pet immunity. The other ones, I don’t get a LOT of false positives but i do get them occasionally.
Do the Iris detectors also act as extenders for Zigbee? I want to install some outdoor path lights and was looking at the below lights but I have no other Zigbee devices and not sure the signal would be reliable enough from the Hub through an exterior wall.
Edit: Or if someone knows something similar to the Lightyify system that is Z wave, they do not need to be RGB, just LED is fine.
I figured that was the case. I may try out the lightfy system and see if it works can always return it to amazon. I only have 1 wall plus the exterior wall that the signal would need to pass through. I also live on a very interior lot, so there are no signals around basically except from my house.
You can try positioning sensors such that they don’t pick up motion closer to the floor. Or looking for sensors with adjustable sensitivity, often advertised as “pet-immune.”
