It does not appear to be. here’s the updated JSON file"
"NetworkReceiver": {
"type": "NetworkReceiverHttpLib",
"port": 8090
"NetworkSender": {
"type": "NetworkSenderHttpLib",
"ip": "192.168.1.24",
"port": 39500
"CompositePeriphs": [],
"Devices": [
"triggers": [
"interval": 500,
"offset": 0,
"command": "poll"
"subscriptions": [
"source": "Switch",
"event": "changed",
"command": "poll"
"type": "Switch",
"name": "Switch",
"output": {
"type": "DigitalOutputPinRaspberryPi",
"initial": false,
"invert": false,
"pin": 16
"invert": false,
"initial": false,
"input": {},
"ignoreRedundant": false
and here’s what I see in the omnithing log:
Sending json: {"updates": [{"name": "Switch", "type": "Switch", "switch": "off"}]}
Return value: 202
Poll triggered for Switch Switch
Return value: 202
Return value: 202
This is what i’m seeing in LiveLogging…it also appears to be inundating my hub with status messages.
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:24 PM: debug sending event: name=switch value=off
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:24 PM: debug parsing [name:Switch, switch:off, type:Switch]
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:23 PM: debug sending event: name=switch value=off
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:23 PM: debug parsing [name:Switch, switch:off, type:Switch]
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:21 PM: debug sending event: name=switch value=off
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:21 PM: debug parsing [name:Switch, switch:off, type:Switch]
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:18 PM: debug sending event: name=switch value=off
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:18 PM: debug parsing [name:Switch, switch:off, type:Switch]
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:17 PM: debug sending event: name=switch value=off
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:17 PM: debug parsing [name:Switch, switch:off, type:Switch]
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:14 PM: debug sending event: name=switch value=off
[648d053d-9938-43db-a505-a46fc7d990b6](https://graph.api.smartthings.com/ide/logs#648d053d-9938-43db-a505-a46fc7d990b6) 5:40:14 PM: debug parsing [name:Switch, switch:off, type:Switch]
Live logging for the parent device:
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:36 PM: debug child with name=Switch exists already.
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:36 PM: debug Searching for child device with network id: BA4D09465798_Switch
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:36 PM: debug parsing updates array
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:36 PM: debug [updates:[[name:Switch, switch:off, type:Switch]]]
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:36 PM: debug received body:
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:34 PM: debug child with name=Switch exists already.
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:34 PM: debug Searching for child device with network id: BA4D09465798_Switch
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:34 PM: debug parsing updates array
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:34 PM: debug [updates:[[name:Switch, switch:off, type:Switch]]]
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:34 PM: debug received body:
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:32 PM: debug child with name=Switch exists already.
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:32 PM: debug Searching for child device with network id: BA4D09465798_Switch
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:32 PM: debug parsing updates array
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:32 PM: debug [updates:[[name:Switch, switch:off, type:Switch]]]
[153da20b-99b2-48c9-a1c3-e35531022e69](https://graph.api.smartthings.com/ide/logs#153da20b-99b2-48c9-a1c3-e35531022e69) 5:41:32 PM: debug received body:
