Hi @SLKDK, This is a driver to a Generic Media Renderer, some old MR takes a lot of time to proccess a command, that is why I have added some delay, to avoid crashes, a new soft MR device is faster, I need to test some Soft MR to try to found the minimun time without crash de Soft device, I will release an update after the test.
@jconnolly1977, Thanks for your comments, I need to update some apps, and write a better description, sorry if its difficult to use them, some steps seems to be ovious after months of working with smartthings, and I forgot that some new users do not know the basics.
Big Talker try to control the device in low mode (controlling every step of process) and it works when its a Sonos or some specific speaker, but I have created generic MR driver to allow most of speakers to work, I have added some delays, and extra steps to allow the faster and slower MR to work, its important the programers use a high level commands to avoid crashes like playTrackAndResume instead of use stop(),load(mp3),play().
Dennon and Technichs allow to play music and restore after a message is played, is the MyAudioStream Pro working in the same way?, please, extend your comments about how is working the MyAudioStream Pro app.
Thanks for your donation
I must not be understanding control points - I tried the Audioremote and the Technics app listed above, and it seems neither supports playing an http - either local or the sound files out at aws. Any thoughts?
Hi @ule - I’ve been using my pure jongo speakers with tts notifications mostly. I did set up MyAudioStream Pro and it worked to trigger music, but for some reason I cannot successfully stop the music. When I press stop or pause from withing the speaker control, it appears it is issuing the correct commands to the control point, but the control point does not produce the intended behavior. Instead of stop or pause, the control point responds with moving to the next track in the playlist. Below is what I am seeing in the device log:
2016-10-05 12:24:53.888 PM EDT DEVICE switch on Jongo Abbys Room switch is on
2016-10-05 12:24:53.881 PM EDT DEVICE status playing Jongo Abbys Room status is playing
2016-10-05 12:24:52.217 PM EDT DEVICE trackData {“station”:“Summer Reiki Musi… Jongo Abbys Room track data is {“station”:“Summer Reiki Music”,“name”:“Summer Reiki Music”,“artist”:”",“album”:"",“trackNumber…
2016-10-05 12:24:52.233 PM EDT DEVICE trackDescriptionSummer Reiki Music Jongo Abbys Room is playing Summer Reiki Music
2016-10-05 12:24:48.306 PM EDT DEVICE switch off Jongo Abbys Room switch is off
2016-10-05 12:24:48.298 PM EDT DEVICE status stopped Jongo Abbys Room status is stopped
2016-10-05 12:24:46.638 PM EDT COMMAND stop stop command was sent to Jongo Abbys Room
2016-10-05 12:24:00.590 PM EDT COMMAND poll poll command was sent to Jongo Abbys Room
2016-10-05 12:24:00.539 PM EDT APP_COMMAND poll
2016-10-05 12:22:36.071 PM EDT DEVICE switch on Jongo Abbys Room switch is on
2016-10-05 12:22:36.063 PM EDT DEVICE status playing Jongo Abbys Room status is playing
2016-10-05 12:22:32.632 PM EDT DEVICE trackData {“station”:“Germany Germany -… Jongo Abbys Room track data is {“station”:“Germany Germany - Rain”,“name”:“Germany Germany - Rain”,“artist”:””,“album”:"","tra…
2016-10-05 12:22:32.646 PM EDT DEVICE trackDescriptionGermany Germany - Rain Jongo Abbys Room is playing Germany Germany - Rain
2016-10-05 12:22:28.613 PM EDT DEVICE switch off Jongo Abbys Room switch is off
2016-10-05 12:22:28.604 PM EDT DEVICE status stopped Jongo Abbys Room status is stopped
I’m assuming this is something particular to my control point. MyAudioStream is available in the app store for free, but limited in functionality unless the pro version is purchased for $2.99 USD. If I press pause or stop on the control point app, the music stops with no problem. I am then able to restart it using the controls within the ST app or schedule track playback with MR events.
Per your request, I will test voice notification behavior during the music playback this week and report what I find.
Hi, I think the control point does not support external control, please , read the section “control point” in the first post, and try to use some of the C.P. I have tested,
@ule I have 8 chromecast audio devices. I am using BubbleUPnP on my dedicated server and created DLNA renderer for each chromecast audio. But when i use MediaRenderer connect app, it is finding only one DLNA out of 8 devices. Do you want me to send any log files? Thanks
Hi, I think the server is using the same uuid, I need the log to check the information and patch the MR Connect
please send me the logs
@ule, Thanks for answering my question. I have attached the logs. It seems to be returning different uuid. But the IP address and port numbers are same. It looks like that is used as the device id.
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:31 PM: trace mediaRendererDiscovery() state.subscribe true
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:26 PM: trace mediaRendererDiscovery() state.subscribe true
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb710104f/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb710104f:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000677c4566/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000677c4566:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000677c4566/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000677c4566:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb710104f/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb710104f:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffad13cc77/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffad13cc77:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000735640dc/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000735640dc:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000735640dc/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000735640dc:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffad13cc77/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffad13cc77:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000381f9983/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000381f9983:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000381f9983/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000381f9983:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb880ca0b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb880ca0b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-00000b4bf48b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-00000b4bf48b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-000037c8250b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-000037c8250b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-000037c8250b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-000037c8250b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-00000b4bf48b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-00000b4bf48b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-000035b2cc87/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-000035b2cc87:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffe2656a30/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffe2656a30:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-000035b2cc87/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-000035b2cc87:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffe2656a30/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffe2656a30:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffff97f7332d/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffff97f7332d:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:25 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffff97f7332d/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffff97f7332d:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:24 PM: debug MediaRenderer device found[devicetype:04, mac:00044B49437D, ip:C0A8007D, port:06AC, ssdpPath:/, ssdpUSN:uuid:ac6dce5a-6047-7862-fd41-e5596960f57a:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:24 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A8007F, port:CB85, ssdpPath:/DeviceDescription.xml, ssdpUSN:uuid:6d2f9a5d-dead-4629-8d45-e4997d16e5ff:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb710104f/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb710104f:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb710104f/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb710104f:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000735640dc/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000735640dc:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000677c4566/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000677c4566:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000677c4566/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000677c4566:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000735640dc/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000735640dc:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffad13cc77/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffad13cc77:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000381f9983/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000381f9983:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffad13cc77/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffad13cc77:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:23 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-00000b4bf48b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-00000b4bf48b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb880ca0b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb880ca0b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-00000b4bf48b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-00000b4bf48b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-000037c8250b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-000037c8250b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-000035b2cc87/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-000035b2cc87:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-000037c8250b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-000037c8250b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffff97f7332d/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffff97f7332d:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-000035b2cc87/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-000035b2cc87:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffff97f7332d/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffff97f7332d:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffe2656a30/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffe2656a30:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffe2656a30/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffe2656a30:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb710104f/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb710104f:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000677c4566/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000677c4566:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000677c4566/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000677c4566:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffb710104f/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffb710104f:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000381f9983/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000381f9983:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffad13cc77/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffad13cc77:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CE, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-ffff-ffffad13cc77/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-ffff-ffffad13cc77:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-0000381f9983/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-0000381f9983:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
5b272469-b150-4280-b5cf-e10bdd9a1858 5:43:22 PM: debug MediaRenderer device found[devicetype:04, mac:001BFCFDB5CF, ip:C0A80080, port:C271, ssdpPath:/dev/4865fac2-0a76-12ae-0000-00000b4bf48b/desc.xml, ssdpUSN:uuid:4865fac2-0a76-12ae-0000-00000b4bf48b:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:1eb55527-03c2-46b0-a1b9-02a04ad62381]
Hi, I see the uui always start with “4865fac2-0a76-12ae” -ffff-ffffad13cc77, Could you install the bubble server in other computer and verify if this is always true.
I need to known if this will be a permanent exception or I need to do another change to avoid lost the id in future.
HI, could you send too the description file
[your ip server]/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/desc.xml,
I am unable to get desc.xml. I tried various urls. I am always getting access denied error. I have enabled remote access on BubbleUPNP . But still i am getting following error.
http://192.168.0.128:58050/dev/4865fac2-0a76-12ae-0000-000037c8250b/desc.xm
http://192.168.0.128:58050/SuperMediaServer/DeviceDescription.xml
HTTP ERROR: 403
Problem accessing /dev/4865fac2-0a76-12ae-0000-000037c8250b/desc.xml. Reason:
Remote access is not allowed
I think the port c271 = 49777 192.168.0.128:49777/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/desc.xml
Thanks :-)… That really helped. It looks like BublleUPnP is changing the port number now and then. From recent smarthings live logging the port number is different ip:C0A80080, port:C27C. So i converted this hex to decimal and used following url
http://192.168.0.128:49788/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/desc.xml
I am getting the file back now. Here is the content of the file
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
<UDN>uuid:4865fac2-0a76-12ae-ffff-ffffb880ca0b</UDN>
<friendlyName>Study (DLNA)</friendlyName>
<manufacturer>Bubblesoft</manufacturer>
<manufacturerURL>
http://forum.xda-developers.com/showthread.php?t=1118891
</manufacturerURL>
<modelDescription>BubbleUPnP Google Cast DLNA renderer</modelDescription>
<modelName>BubbleUPnP Google Cast DLNA renderer</modelName>
<modelNumber>0.9-update20</modelNumber>
<modelURL/>
<serialNumber>0.9-update20</serialNumber>
<presentationURL>http://192.168.0.127:58050</presentationURL>
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMR-1.50</dlna:X_DLNADOC>
<iconList>
<icon>
<mimetype>image/png</mimetype>
<width>98</width>
<height>55</height>
<depth>32</depth>
<url>/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/icon.png</url>
</icon>
</iconList>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
<serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
<controlURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/AVTransport/action
</controlURL>
<eventSubURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/AVTransport/event
</eventSubURL>
<SCPDURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/AVTransport/desc.xml
</SCPDURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
<serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
<controlURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/RenderingControl/action
</controlURL>
<eventSubURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/RenderingControl/event
</eventSubURL>
<SCPDURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/RenderingControl/desc.xml
</SCPDURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
<controlURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/ConnectionManager/action
</controlURL>
<eventSubURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/ConnectionManager/event
</eventSubURL>
<SCPDURL>
/dev/4865fac2-0a76-12ae-ffff-ffffb880ca0b/svc/upnp-org/ConnectionManager/desc.xml
</SCPDURL>
</service>
</serviceList>
</device>
</root>
Do you still want me to try installing BubbleUPnP on a different server?
If its possible will be great just to confirm the first part of the uuid always remain the same
Hi @hobby78 I have created a beta for your chromecast audio with BubbleUPnP server, This connect works if the uuid does not change, the ip and port are updated automatically every sync.
I have program with this considerations
1.- The uuid remains all time
2.- The port and ip can be changed by the server
You must to uninstall all your speakers (from smarthings) and install them again.
send me your feedback
Just update the MediaRenderer Connect with this version
I will appreciated your donations.
Hi @hobby78 , thank you, your donation is very much appreciated, I have detected the player is not updating the information, I’m working on that,
Could you share your exprerience with the Chromecast audio ?
I suggest you to use the media renderer events app, I use it to send music to my speakers from Radionomy stations, very useful.
Hi @ule ,
Fantastic app and is working great for me sending info to a VLC client!
I have however noticed a couple of errors related to the location subscription, it’s not impacting stopping it working though but thought you may want to be aware…
When triggering a routine
I get this:
java.lang.StringIndexOutOfBoundsException: String index out of range: 154 @ line 275
which relates to this line:
def bodyString = new String(parsedEvent.body.decodeBase64())
parsedEvent returns two entries (one blank)
[headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LUxlbmd0aDogMg==, body:T0s=]
Thanks for looking into the player not updating information. My main usage of Media Render(connect) is for setting up Media Render Events. Let me start with a overview of my setup. When i constructed my house couple of years ago, i ran speaker cables to each room. These speaker cables are terminated with HTC multi channel amplifiers. These HTC amplifiers get audio source from a PC. I build a PC with 8 cheap USB audio cards and controlled them through JRiver media center software. This JRiver software creates DLNA Renderer for each audio card . I use their JRemote app to play different music in various zones. Then i came across your Media Renderer smart app. Using that, i play various sounds for various actions. If a garage door is opened, I configured your app to play “Garage door opened” message on kitchen and family room speakers. If mode is away and any of the door sensor is opened , it will play dog barking sound and siren sounds in various speakers. It was working good. But with my JRiver whole house setup, i can’t cast music from my phone or Google Home. I can’t play google play music, youtube from my phone to an audio zone. Then i decided to upgrade my whole house audio from audio pc with sounds cards to Google chrome cast devices. Then i realized your app will work only on DLNA and not on google cast devices. So I started simulating DLNA Renderer using BubbleUPnP software. Now i am getting benefits of google cast as well as media renderer event app benefits also.
Regarding feedback on Chromecast, I am just using Chromecast audio devices. So far, all my 8 chrome cast audio devices are stable. I am able to control them through Google Home easily. I can say “play some news in Kitchen” and “play song in family room” . It is very convenient. Also those can be controlled from smartthings thanks to your software . Out of the box support of smartthings by Google Home is one way. Google Home can talk to smartthings Hub to control things. But thanks to your app, i can control Goolge Home from Smartthings Hub. Since Google Home has an build cast functionality, that can be exposed as DLNA renderer and controlled using your app to play various sounds.
