RELEASE Generic Media Renderer (DLNA Speakers). Cheap Sonos Alternative (Update V2)
Hi @AutomateEverything, The UBI is a DLNA MediaRederer, it must works fine, I have read the UBI has problems with their DLNA implementation, its necesary to update the UBI, once updated it must be found by MediaRenderer Connect, Try to use the Browse UPnP app to verify your network settings, if you cant find it with Browse UPnP you must verify if upnp is eneabled in your router.
Hello,
I’ve been sitting with an problem for a while now.
I use the lario HD and the media renderer. It works when i use the smartthings labs sonos ā€œplay a sound or custom message through your sonosā€. Though the custom message doesn’t work, the dogs bark pretty well :smile:
But when i try bigtalker, it finds the lario hd speaker, but there just won’t be any sound.
Is this connected to the problem that the smartthings labs -> sonos sound, wont play any custom message?
Because the sounds from bigtalker are also ā€œcustomā€ messages?
Has anyone else had issues finding UBI’s with this ?
Ive installed @jody.albritton’s device type for the ubi’s and ive uses BROWSE UPNP to find the Ubi’s and they BROWSE UPNP app can see the ubi’s but Generic Media Renderer cant find them . . .
hmmm
I am using a Lario HD with the ā€œSonos Notify with Custom Soundā€ app to play custom messages and it works more or less fine (besides delays). The dog works fine, too. So your setup should work in general. I have ā€œResume currently playing musicā€ set to off and ā€œTemporarily change volumeā€ set to 100.
I never got the ā€œBig Talkerā€ App to play custom messages though.
I think this has to do with the fact that there are 2 ways to render text to speech in Smartthings: capability.speechSynthesis/speak(string) and speechDeviceType/playText(string). E.g. when you install the ā€œBig Talkerā€ app you have to initially choose between Sonos/VLC THing and Ubi/VLC thing. From what I understand this selects one or the other method. From what I understand you have to select Sonos for the Lario to work. Sorry - I know this does not solve your problem but may be good background.
Hi
SmartTings platform is not working fine, the text to speach function does not works, every app who use the text to sepach (tts) function will be fail , some apps run the tts function and save the audio url to send to MediaRenderer others apps send the text and MR run the tts function.
Some texts have been cahed and works fine, but if you are using new text will be fail.
We only can to wait SmartThings Fix the tts function problem.
You can send a mail to support, maybe if they get a lot of mails about fix the function they can mark this issue with a priority flag
I’m using Foobar and control works fine via ST, but when using the Sonos Smart App to play a song, it shows the tracks in the Foobar library but says Unavailable next to each track. Has anybody seen this? Or does the library on Foobar not work with this?
Hi @sgord, I have test the MR Device and is working fine with foobar2000, I have loaded some songs in playlist and start plying pushing play button in device interface from smartthings, the next track and previous track work fine, try to control the foobar2000 from device interface just to confirm the device is working fine, maybe the problem is in the app and not in the device
@ule. Hey thanks! I can control foobar2000 just fine from within ST. It will play the songs, but I’m trying to have it play a specific song/sound for certain options. I dont really understand the whole control point portion of this setup though.
Hi @sgord, Try to use the app ā€œSonos notify with soundā€ you can select some previous played song to use in some alert,
The text to Speech function is not working in SmartThings plataform, try avoid use that function, I hope in some short time ST fix the bug. Remember that Music Device is not a control point to load music playlist, is mainly to send alert messages and continue your playlist, you must to control your music with some advanced DLNA control point like the listed in first post.
Hi, sorry by delay, now I have and Android phone and I have fixed the error when you try to install the players from the media renderer connect, please update the Mediarenderer Connect App and install your speakers
This problem was present just in android devices.
Thank you!
I experienced the problem, but didn’t have a chance to follow up. This is a fantastic project, thank you for your continual support and development!
Hi, I have found a work around the problem with Text To Speach function.
Smartthings plataform have problems to convert tex to to audio long time ago and they have not a date to fix it
A replace function calls a google service to convert on the fly.
If you are a user: You must to update the DLNA PLAYER device
And to use the modified smartapps with the new function. (I have mod some smartapps from smartthings )
This must to be a temporal fix until SmartThings fix the problem.
If you are a programer: You must to add the new function and replace the call of the old function with the new one on yours smart apps
Thanks for follow this development
Read the next post
@sgord I did finally get it to work. Actually picked up two other and grouped them so I have a ā€œvoiceā€ for the whole house by sending to the group instead of individual. That said, I recently rebuilt everything onto the v2 Hub, and since then it’s clipping the end of the audio off no matter what I do with the delay timers. I’m assuming this is a side-effect of upgrading but still investigating…
I tried the updated connect app (v1.9.1), but I’m still having issues with discovery of MediaRenderers.
According to the log a number of devices are found, showing up as the one below:
MediaRenderer device found[devicetype:04, mac:XXX, ip:XXX, port:XXX, ssdpPath:/, …
I can also see that the method to add them to the state dictionary is called, and the device is recognized between calls to the locationHandler.
However, the device is still not listed in the GUI.
The issue is the same both using the Android app and the simulator.
Is anyone else seeing this?
I’m not too familiar with the design of SmartApps yet, but the designs of the mediaRendererDiscovery function suggests that it is supposed to be called periodically at ā€œrefreshIntervalā€. This does not seem to happen.
Neither can I find any information on the refreshInterval attribute in the documentation?
HI @Manana546, Could you give me more information?, what Mediarenderer model do you want to add?
Could you send me the log when you try to add the MR
The Mediarenderer is found by other control point listed in first post?
@ule It is a HEOS 7 (http://usa.denon.com/heos-7-large-home-speaker-system). It can be found by other control points, from the ones in your first post i have only tried ā€œNetwork Audio Remote Androidā€, but that one worked.
I have added a more comprehensive log below:
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: trace Host: 192.168.14.31:80 - 192.168.14.31:80
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: debug Device (0017881764C2) was already found in state with ip = 192.168.14.31:80.
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: trace [uuid:2f402f80-da50-11e1-9b23-0017881764c2:[ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2, verified:true, networkAddress:C0A80E1F, name:Olskroken (192.168.14.31), serialNumber:0017881764c2, deviceAddress:0050, mac:0017881764C2, devicetype:04, hub:ad1c9cf5-5065-45b3-8880-6db2064eadfd, ssdpPath:/description.xml, ssdpTerm:urn:schemas-upnp-org:device:basic:1, stringCount:03]]
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: trace SSDP DISCOVERY EVENTS
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: trace Location: devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2, ssdpTerm:urn:schemas-upnp-org:device:basic:1
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: trace NON-HUE EVENT devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-0017881764c2
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: trace Location: devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-0017881764c2
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: trace NON-HUE EVENT devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2::upnp:rootdevice, ssdpTerm:upnp:rootdevice
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:05: trace Location: devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2::upnp:rootdevice, ssdpTerm:upnp:rootdevice
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace Host: 192.168.14.31:80 - 192.168.14.31:80
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: debug Device (0017881764C2) was already found in state with ip = 192.168.14.31:80.
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace [uuid:2f402f80-da50-11e1-9b23-0017881764c2:[ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2, verified:true, networkAddress:C0A80E1F, name:Olskroken (192.168.14.31), serialNumber:0017881764c2, deviceAddress:0050, mac:0017881764C2, devicetype:04, hub:ad1c9cf5-5065-45b3-8880-6db2064eadfd, ssdpPath:/description.xml, ssdpTerm:urn:schemas-upnp-org:device:basic:1, stringCount:03]]
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace SSDP DISCOVERY EVENTS
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace Location: devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2, ssdpTerm:urn:schemas-upnp-org:device:basic:1
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace NON-HUE EVENT devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-0017881764c2
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace Location: devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-0017881764c2
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace NON-HUE EVENT devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2::upnp:rootdevice, ssdpTerm:upnp:rootdevice
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace Location: devicetype:04, mac:0017881764C2, networkAddress:C0A80E1F, deviceAddress:0050, stringCount:03, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017881764c2::upnp:rootdevice, ssdpTerm:upnp:rootdevice
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace NON-HUE EVENT devicetype:04, mac:0005CD467294, networkAddress:C0A80E9F, deviceAddress:EB64, stringCount:03, ssdpPath:/, ssdpUSN:uuid:e85d14ac-60ae-1b4e-0080-0005cd467294::urn:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1
15d1aba8-07ca-47ca-83fa-02f7f76db227 17:54:04: trace Location: devicetype:04, mac:0005CD467294, networkAddress:C0A80E9F, deviceAddress:EB64, stringCount:03, ssdpPath:/, ssdpUSN:uuid:e85d14ac-60ae-1b4e-0080-0005cd467294::urn:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1
ff8b168b-c62e-4733-a995-301167f7b5dd 17:54:04: debug MediaRenderer device found[devicetype:04, mac:0005CD467294, ip:C0A80E9F, port:EB64, ssdpPath:/, ssdpUSN:uuid:e85d14ac-60ae-1b4e-0080-0005cd467294::urn:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:ad1c9cf5-5065-45b3-8880-6db2064eadfd]
Hi @Manana546, I think you have other smartapp connect who has take control over the mediaRenderer
the 15d1aba8-07ca-47ca-83fa-02f7f76db227 is the other smartapp connect who has take control
the Mediarenderer connect must to be app id : ff8b168b-c62e-4733-a995-301167f7b5dd (in your system)
I suggest you to uninstall the device from the other smartapp and try to find the mediarenderer again with the Mediarenderer Connect, I think the other smartapp do not limit the upnp search.
The device at 192.168.14.31:80 is my HUE bridge. I removed all but one MediaRenderer and it is at 192.168.14.159.
Just to be safe i also removed the HUE completely from smartthings, but unforturnately that doesnt help.
I added a line in the beginning of the mediaRendererDiscovery, the discoverMediaRenderers and the verifyMediaRendererPlayer functions to keep track of them.
Log:
78bdf52b-3709-438b-827b-d9e688d8de57 7:52:15 AM: trace daysOk = true
78bdf52b-3709-438b-827b-d9e688d8de57 7:52:15 AM: debug startTime: 2015-09-23T05:00:00.000+0200, endTime: 2015-09-23T14:00:00.000+0200, t0: Thu Sep 24 05:52:15 UTC 2015
78bdf52b-3709-438b-827b-d9e688d8de57 7:52:15 AM: trace motionActiveHandler(motion: active), timeOfDay: 2015-09-23T05:00:00.000+0200, endTime: 2015-09-23T14:00:00.000+0200
4d9b3106-25b6-4674-a134-3e9eb6d4da33 7:52:15 AM: debug Motion active
c5d259aa-15f5-4b80-9ce8-fcb83057093b 7:52:15 AM: debug Parse returned [name:motion, value:active, descriptionText:Livingroom Window detected motion]
c5d259aa-15f5-4b80-9ce8-fcb83057093b 7:52:15 AM: debug motion
c5d259aa-15f5-4b80-9ce8-fcb83057093b 7:52:15 AM: debug motion with tamper alarm
c5d259aa-15f5-4b80-9ce8-fcb83057093b 7:52:15 AM: debug description: zone status 0x0022 -- extended status 0x00
84331174-ed11-4a07-800b-ac97b12ca9f2 7:50:29 AM: debug MediaRenderer device found[devicetype:04, mac:0005CD467294, ip:C0A80E9F, port:E319, ssdpPath:/, ssdpUSN:uuid:e85d14ac-60ae-1b4e-0080-0005cd467294::urn:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:ad1c9cf5-5065-45b3-8880-6db2064eadfd]
84331174-ed11-4a07-800b-ac97b12ca9f2 7:50:28 AM: debug discoverMediaRenderers called
84331174-ed11-4a07-800b-ac97b12ca9f2 7:50:28 AM: debug mediaRendererDiscovery called
Hi @Manana546, I can see it now, the mac address is different, I think the smartthing hub is not catching the confirmation response from the media renderer, I have experience this kind of problem once in 100 times when I install and uninstall the media renderer, I dont know why happens, but the solution I have follow is to change the mediarenderer ip address, you can change the ip directly in your mediarenderer or you can change it in the router. try it
Well, that’s a bit annoying.
I changed the IP of the mediarenderer and now the discovery seems to work better when used in the Android app. The GUI still shows ā€œ0 devicesā€ but the log seems a lot better.
Calling the discovery from the simulator still suffers from the same disapearance of confirmation responses.
EDIT: I also tried accessing 192.168.14.138:58137 in my browser, and that returns a proper XML. Added it to the post.
Log when using the Android app:
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:57: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:57: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:52: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:52: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:52: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:52: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:47: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:47: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:47: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:47: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:42: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:42: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:42: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:42: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:36: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:36: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:36: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:36: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:31: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:31: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:31: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:31: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:26: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:26: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:26: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:26: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:22: debug MediaRenderer device found[devicetype:04, mac:0005CD467294, ip:C0A80E8A, port:E319, ssdpPath:/, ssdpUSN:uuid:e85d14ac-60ae-1b4e-0080-0005cd467294::urn:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:ad1c9cf5-5065-45b3-8880-6db2064eadfd]
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:21: debug discoverMediaRenderers called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:21: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:15: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:15: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:15: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:15: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:10: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:10: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:10: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:10: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:05: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:05: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:05: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:44:05: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:59: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:59: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:59: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:59: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:54: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:54: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:54: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:54: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:49: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:49: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:49: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:49: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:44: debug verifyMediaRenderer ip:192.168.14.138:58137 ssdpPath:/
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:44: debug verifyMediaRenderer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:44: debug verifyMediaRendererPlayer called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:44: debug mediaRendererDiscovery called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:41: debug MediaRenderer device found[devicetype:04, mac:0005CD467294, ip:C0A80E8A, port:E319, ssdpPath:/, ssdpUSN:uuid:e85d14ac-60ae-1b4e-0080-0005cd467294::urn:schemas-upnp-org:device:MediaRenderer:1, ssdpTerm:urn:schemas-upnp-org:device:MediaRenderer:1, hub:ad1c9cf5-5065-45b3-8880-6db2064eadfd]
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:38: debug discoverMediaRenderers called
814a87be-65bb-4751-bd9e-05a287b0f676 09:43:38: debug mediaRendererDiscovery called
XML from 192.168.14.138:58137
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<deviceType>urn:schemas-denon-com:device:AiosDevice:1</deviceType>
<friendlyName>Bedroom</friendlyName>
<manufacturer>Denon</manufacturer>
<manufacturerURL>http://www.denon.com</manufacturerURL>
<modelName>HEOS 7</modelName>
<modelNumber>DWS-7000 3.0</modelNumber>
<serialNumber>NOT CONFIGURED</serialNumber>
<UDN>XXXXXXXXXXXXXXXXXXXXX</UDN>
<deviceList>
<device>
<pnpx:X_hardwareId xmlns:pnpx="http://schemas.microsoft.com/windows/pnpx/2005/11">VEN_121&DEV_30</pnpx:X_hardwareId>
<pnpx:X_compatibleId xmlns:pnpx="http://schemas.microsoft.com/windows/pnpx/2005/11">MS_DigitalMediaDeviceClass_DMR_V001</pnpx:X_compatibleId>
<pnpx:X_deviceCategory xmlns:pnpx="http://schemas.microsoft.com/windows/pnpx/2005/11">MediaDevices</pnpx:X_deviceCategory>
<df:X_deviceCategory xmlns:df="http://schemas.microsoft.com/windows/2008/09/devicefoundation">Multimedia.DMR</df:X_deviceCategory>
<df:X_containerId xmlns:df="http://schemas.microsoft.com/windows/2008/09/devicefoundation">{5cb01ae2-3a9e-1a10-0080-0005cd467294}</df:X_containerId>
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMR-1.50</dlna:X_DLNADOC>
<deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
<UDN>YYYYYYYYYYYYYYYYYYYYYYYYYYYY</UDN>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
<serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
<SCPDURL>RenderingControl/scpd.xml</SCPDURL>
<controlURL>RenderingControl/control</controlURL>
<eventSubURL>RenderingControl/event</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
<SCPDURL>ConnectionManager/scpd.xml</SCPDURL>
<controlURL>ConnectionManager/control</controlURL>
<eventSubURL>ConnectionManager/event</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
<serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
<SCPDURL>AVTransport/scpd.xml</SCPDURL>
<controlURL>AVTransport/control</controlURL>
<eventSubURL>AVTransport/event</eventSubURL>
</service>
</serviceList>
</device>
<device>
<deviceType>urn:schemas-denon-com:device:AiosServices:1</deviceType>
<friendlyName>AiosServices</friendlyName>
<UDN>ZZZZZZZZZZZZZZZZZZZZ</UDN>
<serviceList>
<service>
<serviceType>urn:schemas-denon-com:service:GroupControl:1</serviceType>
<serviceId>urn:denon-com:serviceId:GroupControl</serviceId>
<SCPDURL>GroupControl/scpd.xml</SCPDURL>
<controlURL>GroupControl/control</controlURL>
<eventSubURL>GroupControl/event</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-denon-com:service:ZoneControl:2</serviceType>
<serviceId>urn:denon-com:serviceId:ZoneControl</serviceId>
<SCPDURL>ZoneControl/scpd.xml</SCPDURL>
<controlURL>ZoneControl/control</controlURL>
<eventSubURL>ZoneControl/event</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-denon-com:service:ErrorHandler:1</serviceType>
<serviceId>urn:denon-com:serviceId:ErrorHandler</serviceId>
<SCPDURL>ErrorHandler/scpd.xml</SCPDURL>
<controlURL>ErrorHandler/control</controlURL>
<eventSubURL>ErrorHandler/event</eventSubURL>
</service>
</serviceList>
</device>
</deviceList>
<presentationURL>settings</presentationURL>
</device>
</root>
