The embedded SmartThings Weather Station, which is what supplies the sunrise/sunset info for your location, is a cloud-based app. Thus, if you create a Smart Lighting automation that uses sunrise/sunset, it indeed is forced to run in the cloud.
By the same token, since my MeteoWeather DTH also (is forced to) run in the cloud, it can’t help you be totally local. In fact, the only way I know to do sunrise/sunset stuff locally is to switch to Hubitat…
I been busy with work. I’ll get to it in the morning.
I want to let u know that I updated to a vp2 plus with a meteobridge nano SD. It did work so I am sure it works with your previous version. Oh and by the way I did reboot and had no effect. Tomorrow Il get the logs for you.
MeteoWeather Station version 1.1.28 released 26 June 2019 at 9:55pm EDT
Fixes icon display during transition period between night/day and day/night
Now displays properly in the Hubitat Dashboard’s Weather tile template
Wind speed and wind direction fixed. NOTE: this fix required changing the meaning of two attributes:
windDirection is now the direction the wind is coming from in degrees (0-360) - was direction text, i.e. NNW
windDirectionDegrees is no longer updated
windDirectionText is now the wind source direction text (NNW) - was direction degrees, i.e.,
345
Now displays proper weather icon (translated to OpenWeatherMap icons)
Now fully supports an “optimized” template call to the MeteoBridge (new preferences option)
Use of averaged values is now a preferences option
NOTE: If you have problems getting data to display, please try updating your MeteoBridge system software - there have been fixes made to the MeteoBridge software to address issues discovered with the optimized template and averaged values.
Apologies for asking a dumb question, but a network ID was not assigned when I installed the Meteobridge Weather Station. I’ve been through the available instructions and I can’t figure out what goes in this field when I define the new device. Help!
