I am having the same issue discovery as someone earlier, the GH announced when the server came online but the SmartApp cannot discover it. It is running on a win10 box with firewall disabled for testing. I am able to sent post commands that work and announce on GH using “curl -X POST http://10.0.0.99:3000/customBroadcast?text=hello+world&user=myname” from my ubuntu server via putty, command also works from the bash shell in Windows after I installed it.
Is there a way to hard code the IP somewhere? Or has anyone else had this discovery issue?
No, it says “Starting Discover” and the little hamster wheel just spins and spins. I changed the IP of the server to a lower IP thinking that the discovery does an IP sweep starting at the beginning of the subnet, have restarted everything
looks like Untangle is screwing me. So either i need to hard code it or I will investigate “WebCore to send a POST request to the IP address of the relay manually” as I have Core running…but no idea where to add this.
So according to Untangle they do not support IGMP. I have a Ubiquiti switch at the core of my network that does support it but changing it made no difference. I dont really understand IGMP but it does not seem like that would be the issue from what I read. Does the app, as part of its discovery just do a ping sweep of the current network looking for IPs the respond and then check for a response on port 3000? Is there not a way to set the IP of my node server in the code itself? Also, I cannot figure out for the life of me how to get webcore to create an item that I can send messages to given that I cant get the device to be discovered. so if anyone who has made WebCore work with the relay service node WTHOUT needing to use the smartapp or device handler on the ST app could pointy me in the right direction I would appreciate it.
I will make a feature request to be able to add the IP manually either in the code or in the ST App GUI. Regardless, this project and the hard work are greatly appreciated!
For anybody wondering, or struggling with the discovery process, you can ignore it if you set up the device correctly in ST. As an outline, the steps to do this are as follows:
Install the device handler by pasting as code into the IDE
Go to the Devices section of the IDE and create a device for Google Home Assistant, following this pattern that I used:
Note that your Device Network ID should be as follows: IP:Port in HEX, hence mine is 192.168.1.2:4000 which translates to C0A80102:0FA0 - you will likely need to change the 0102 section at the end to the correct IP, and you are probably using port 3000 (default) which means then ending should be :0BB8 rather than :0FA0
You can now send a test command through CoRE/WebCore and everything should be working, without needing the discovery SmartApp.
Thank you! The above worked like a charm, just like the rest of this project! I really appreciate you taking the time to create this project, it is so needed!
Anybody know where there’s guidance for Smartthings integration? I see in Greg’s initial post a reference to a guide made by Danabw, but that doesn’t describe how you actually add the repository and DTH. I’m an old fart, new to SmartThings, and am probably trying to run before I can walk, but I don’t quite understand the steps needed to get the Assistant Relay linked to ST. I’ve got Assistant Relay setup and it’s working great (thanks for sharing this Greg). Also have WebCoRe installed and having fun with that. Ultimate goal is to have it exposed to WebCoRe, but assume I need to add it through the Smartthings IDE first, correct?
Really appreciate your feedback. Making me stare at that second link may help get me back on the right track.
I may not have shaped my question well due to my lack of understanding the fundamentals. I already had GitHub linked from previously setting up WebCoRe. The first post in this thread says, “you can either add in my repository to the IDE, or manually copy in the SmartApp and DTH from my repository.” That’s the step I’m hung on - as I’m not sure where to point to find/pull in the custom code. I assume that’s my next step to make SmartThings recognize assistant-relay as a device/thing.
I think I just need to know where to go to pull the SmartApp and DTH code, then follow the steps in Section II from the 2nd link you provided. Does this sound anywhere close to right?
The code is under the devicetypes and smartapps links:
You can also integrate Greg’s repository into your IDE (if you’re familiar w/that, and I would expect you are from webCore setup) using the info below:
Perfect - just what I was after. Thanks again! That got me on to my next problem, where it momentarily finds the relay, but stays in eternal discovery and throws an “Unexpected Error” message when I save. I see others have had the same issue so I’ll read up to see how to dig out. Appreciate your patience Dana.
