QS-Zigbee-D02 Device Hander for 2 Gangs dimmer
Unfortunately this driver still not working fine. Please refer to the attached video, notice that trying to adjust level of child driver if bringing back the initial level. While no effect in light dimming.
More logs will be send tomorrow:
NO Problems if controlling from single control without child
Hi @dotan_shai
This version must fix the problem
 Name         Zigbee Multi Switch and Child Test
 Version      2022-11-13T18:15:32.441461963
Still no luck with child device. This time the slider is moving to the desired position but no effect on light.
Again in Single control, no problems. Here are some logs:
141122_log_dimmer.txt - Google Drive
@dotan_shai
Try this version and sens my the logs, please
 Version      2022-11-14T20:22:59.776340648
Hi @dotan_shai
Does this version work well?
@Mariano_Colmenarejo
Still works the same.
From Father 1st dimmer and 2nd dimmer works fine
From Child - Only on/off works NO DIMMING. Here are some logs:
Hi @dotan_shai
In this log I see the error when send the level command
This version must be fix
 Version      2022-11-17T19:43:55.779219212
That’s it !!
You got it working !!!
All OK you can add it to your Switch and Child (Not test)
Hi @dotan_shai. I’m facing the same issue. Sorry if this is a noob question but I can’t find the code @Mariano_Colmenarejo sent you. Can you post it again please? Tks
No code…
Just join @Mariano_Colmenarejo channel and install Driver.
His channel is here:
and install driver Zigbee Multi Switch and Child (not test)
Thanks a lot! I’ll give it a try as soon as I get home! :upside_down_face:
This is brilliant. I’ve got another version of the same dimmer branded by Moesgo (amazon.co.uk/gp/product/B09Y1C59TS). I’ve subscribed to the channel and installed Zigbee Multi Switch and Child Mc driver, but I can’t change the driver from Zigbee thing to the multi switch. The model number etc is different.
Mariano, could you please associate the information for the Moesgo 2 gang dimmer switch with your driver.
Many thanks
Mike
Hi @Mike_B1
Sorry, this device use Tuya cluster EF00 and can’t work with this driver
I don’t know if it could work with any @ygerlovin driver
Hi @Mariano_Colmenarejo
Thank you for the quick reply. Clearly, I was overly hopeful. I’ve just tried @ygerlovin 's drivers and they don’t seem to work with it.
Have a great Christmas!
may need to add the manufacturer and model to the driver.
Merry Christmas
