Power Outage Notification
Hi,
I was wondering if there is a way to get notified of a power Outage If I am not at home.
thanks
I guess you would only know that by polling or pinging your hub/router and notifying if it fails to connect.
If you have no power your router would not be powered and connected to the Internet to send a message
Hi,
My internet connection is always on even in case of a power outage.
Considering that V2 hub has battery there must be a way on the hub to know that is using battery instead of the power cable.
Fab
Do you have one of the outlets? I’m not aware the hub is contextually aware itself, there maybe something in the ide but I’m new to smartthings and still learning.
If you have an outlet plugged into something always on then I guess you could have the ā€˜notify if’ app send a notification if the power consumption drops to 0 or the plug becomes inactive (as there is no power).
yes I have cable modem switches and router on ups’s… I have an aeon home energy monitor hooked up… there is a smart app to show power outage… if reading on monitor is less than some amount… I just realilzed I need to put batteries in that however so it reports when the power is out.
Yes,
Alas, they broke this in v2. I am trying to get a resolution from support, @slagle etc., but it is going on two months now with no answer.
I just got it to work with this version of the devicetype.
https://raw.githubusercontent.com/SmartThingsCommunity/SmartThingsPublic/6ad3c4fd7a616582f2a9cbb6ae24070ec31474a7/devicetypes/smartthings/smartsense-motion.src/smartsense-motion.groovy
Thanks so much!!!
So they update the stock deviceType, which breaks it. You report it broken, and no one has a clue as to why (ā€œwe’re gonna have to have engineering look into itā€). Little wonder things are as screwed up as they are. Again my thanks, this was pretty darned important to me where I live (which I mentioned numerous times to support).
Pretty much exploiting the same logic, I’ve been using this elegantly simple app by @twack https://github.com/twack/smarthings-apps/blob/master/SocketPowerIsOut.app.groovy
I’m running the v1 hub powered off the USB port of my router that’s hooked to a UPS.
The solutions I have found in the forums exploit the V1 motion sensor (specifically the usb-power to battery-power switching), which seems hard to come by these days. All new motion sensors are strictly battery powered now, and ebay has yet to notice the value inherent in the vintage motion sensors. Anyone noticed other posts with alternative solutions to power outage reporting?
You can use the Fortezz MimoLite. It actually will send a notice when it looses power. Look at my doorbell project and with a little editing you’re there.
Bug me if you need additional help.
Since Smartthings V2 missed the boat and can’t even alert/notify when the Hub goes on and off of internal battery power, you would think that they would at least enable the USB ports so I could connect a UPS to the Hub and the Hub could then sense if power is out from the connected UPS via the USB port. How about doing this?
Is it possible that this is still not available in the v2 hub? this seems like the most basic of all home automation features. i am going to hazard a guess that power outages happen far more often than break ins. i have been searching the forums to see if the solution is just posted on a different thread but have not been able to find any. has there been any update since june?
No solution as far as I know
I solved with my android tablet (which is being used with smarttiles) with the android battery channel on ifttt
Thanks, this is the easiest solution I have seen on here
did you create an applet for this on ifttt
Yes it sends me a pushover notification when the android tablet lose power
Ted 5000 or Ted Pro Home, both work great
http://www.theenergydetective.com/compare
I used $10 Aeon Labs Energy Meter.
