I am now using this SmartApp to cycle power to a GE z-wave outlet that has a Simple Hub (from Simple Control) plugged into the outlet. The Simple Hub has a problem that the developer either cannot fix, or will not admit is a problem, or I have a network problem that only affects the Simple Hub, because it goes ‘offline’ every 2 to 3 days in the sense the iPads cannot “see it”. Been troubleshooting with the developer of the Simple Hub for weeks. Power-cycling the Simple Hub fixes it for another 2 or 3 days until it happens again. So, I am using this app to simply cycle power to the Simple Hub for 5 seconds every day at 3 am.
This is not the ideal ‘fix’ but this SmartApp works perfectly for an interim solution!
Thank you developer for writing and posting this!
