Has anyone replied to this yet, I have the same buttons?
Unfortunately not. ![]()
Since you want light control instead of sound, have you looked at the STYRBAR remote control? (203.033.17 TRΓ DFRI remote control, Gen 2)
You can use STYRBAR remote to control up to 10 LED light bulbs at a time - dim, switch on and off, and step by step change from warm to cold light.
Plus it looks like the STYRBAR and/or TRΓ
DFRI remote control is already supported:
Throwing this out thereβ¦ I have searched through community drivers as well as I canβ¦but nothing has turned upβ¦ zigbee thing shows the following information.
No expectations !
Manufacturer: Lutron
Model: LZL4BWHL01 Remote
FingerPrinted_EndPoint.Id: 0x01
App Version: 0x01
ZCL Version: 0x01
Network ID: 0x76E4
Zigbee EUI: FFFF000FE7FF50CE
Device ID: 96403ecf-fb6c-42ea-9898-535b8a26965e
Server Cluster:
Ep: 0x01={ 0000,1000,FF00,FC44 }
Client Clusters:
Ep: 0x01={ 1000,0003,0006,0008,0004,0005,0000,
FF00 }
BUMP β¦still waiting on these devices to transition to Edge and getting anxious. If they wind up as generic βTHINGSβ and lose functionality, thatβll put me in a pinch. Monoprice (product # 24259) Z-Wave Plus Door/Window Sensor, which are just rebranded HANK (model HKZX-DWS01)
zw:Ss type:0701 mfr:0208 prod:0201 model:0008 ver:1.04 zwv:4.34 lib:03 cc:5E,98,86,72,73,5A sec:71,59,85,80,84,70,7A role:06 ff:8C00 ui:8C00
zw:Ss type:0701 mfr:0208 prod:0201 model:0008 ver:1.05 zwv:4.34 lib:03 cc:5E,98,86,72,73,5A sec:71,59,85,80,84,70,7A role:06 ff:8C00 ui:8C00
zw:S type:0701 mfr:0208 prod:0201 model:0008 ver:1.04 zwv:4.34 lib:03 cc:5E,86,72,71,59,85,80,84,73,70,7A,5A role:06 ff:8C00 ui:8C00
Hey @Mariano_Colmenarejo any chance you would be able to help with an edge driver for this scene controller?
Hi @Jay316
Sorry, I canβt do it.
I donβt even know how this device works
Since your device contain EF00 cluster, try to use this custom driver:
Hopefully , youβll be able to control your device.
Seems to be working with stoke ST edge driver:
Works with stock edge driver but unfortunately itβs not showing the battery level property.
Hi @Jay316
Try this driver version.
they physically look the same, but may not function the same
ββββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Z-Wave Sensor and Child Thermostat Mc
Version 2023-03-22T16:49:32.37711313
- id: 0060/0002/0003
deviceLabel: Everspring Open/Closed Sensor
manufacturerId: 0x0060
productType: 0x0002
# productId: 0x0003 # 0x0002 mod 22/03/2023
deviceProfileName: contact-battery-tamperalert
Buy and send the device data to create the drive.
Hi @Icecream
Added to this driver version
Name Zigbee Contact Mc
Version 2023-03-23T11:35:22.186072591
- id: "_TZ3000_hdtmulpn/Contact Sensor"
deviceLabel: TS0203 Contact Sensor
manufacturer: _TZ3000_hdtmulpn
model: TS0203
deviceProfileName: contact-battery-profile
OMG so fast. Thank you so much.
Just an update on my keypad (not that its a great one) but Now it comes up as a zigbee thing (so ST sees it which is a good start). Im hoping to find an edge driver for this. If anyone has found one please let me know.
@RBoy use to have DHT for this device (not free), hopefully he will convert the DHT to Edge Driver so you will be able to use itβ¦
Hi.
Answer to ELKO SuperThermostat:
I think this is hard to do without a device for test. Some special attributes for thermostat, so a generic driver will not work well.
I can try first with setpoint and temperature and see if it will work.
Are you willing to test?
Iβll be more than happy to try it out.
The DTH linked in my original post works well if that helps you in any way.
