I performed the remove Device handler task, installed and enrolled the folllowing deivers from your channel
Motion
Contact
Thing
Multi Switch and Child
And all of my Nue 3A switch devices are working well. Even the 2, 3 and 4 gang devices.
A Massive thank you and appreciation for your efforts in supporting these devices!!!
Some notes of advice for users around my level of expertise, ( low-mid level), i couldnt find these small tops anywhere else so wanted to post them for others.
1.I was very reluctant , and had delayed performing this work to because if the drivers didnt pick up the device, id have been in a difficult spot. But the response time from the community posts was so quick id encourage others to take the plunge.
2.Marianos Zigbee Thing Mc driver needs to be manually selected, and this can only be done when its already on another driver. ( i was trying to find a way to manually select it when i still had my old DTHs installed.) This is shown in the settings of the device under driver as below.
I now understand this driver is like a universal fallback to at least get the main cluster and device id information, ,( that wasnt clear to me before) if another driver doesnt work.
For the multi switches there is an options setting to Create single device for Switch X. Took me a while to find it. But in case this is your preference.
It would be great to get a driver that supports keypads. I also have an old Iris keypad that I used to have working with a custom device handler and smart app.
Good Afternoon, @Mariano_Colmenarejo Could you please add the fingerprint of the Lonsonho brand zigbee socket plug (Plataforma Tuya) to your Zigbee Switch MC driver. Attached is the print of the fingerprint of this device.
Good Afternoon, @veonua Could you please add the fingerprint of the temperature, humidity and VOC sensor. The Aqara TVOC.To your temperature and humidity sensor driver. Hereβs the fingerprint data I got from the Groovy IDE.
I was hoping someone could update the Edge driver for the Ikea Tradri bulb E26 WS clear 806lm. The current driver works, but doesnβt show any of the bulb settings (Color temperature match dimming, fade on, etc) that used to be available with groovy.
Hi all, love the work going on here!
Any chance anyone can help me out with an edge driver for a zigbee fan/light switch? I hear it doesnβt have the fan control cluster, so even just turning it into four buttons would be suitable.
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2023-01-19T22:01:44.536907542
- id: "3A Smart/LXN56-1S27LX1.2"
deviceLabel: 3A Smart 4 Switch
manufacturer: 3A Smart Home DE
model: LXN56-1S27LX1.2
deviceProfileName: four-switch
Good afternoon, @Mariano_Colmenarejo could you please add the 10 a / 20 A zigbee dual socket from Zemismart (Tuya) to the Zigbee Multi Switch and Child Mc driver. Below is his data that appears in Groovy.
Added to this driver version
As it has clusters for energy and power then I added to profile with power and energy.
Try if works fine
Version 2023-01-20T19:33:37.947313555
- id: "TS011F/_TZ3000_6s5dc9lx"
deviceLabel: TS011F Two Plugs
manufacturer: _TZ3000_6s5dc9lx
model: TS011F
deviceProfileName: two-switch-power-energy
