Hello everyone, I am trying to find the correct driver for the Zigbee Securifi Almond Click button. I added the Zigbee Button driver but after removing the device and DH, and re-adding it did not grab the driver.
I waited until the last minute think everything would switch over ofer the cut over but only my samsung button moved over to the drivers automatically.
I’m just starting to try to switch Trippers over to @Mariano_Colmenarejo ’s driver. I’ve only tried w/ a couple so far, but having the same issue where they are not fully onboarding. I have a hypothesis that it may have something to do with their not connecting directly to hub at first - I’ll be testing that out. They are, as their name says, Quirky! (But I have 25 of them and they have been rock solid on Smart Things all along - so I’m pretty motivated!).
When you say you changed the driver - were they already on another Edge driver - or are you switching them from a DTH?
@Mariano_Colmenarejo i was looking for an edge driver for my sengled light strips & came across a post from you mentioning you made one. Is that something that i can use with mine also?
Dom
Looking for a driver for an Iris / Centralite Zigbee Keypad that will work to arm and disarm STHM. Had been using Rboy’s zigbee driver and keypad smartapp combo, but I don’t think it’s going to make the transition to Edge.
It can be simple - single code for access, just need the disarm, arm/stay, arm/away functionality. Would be nice to have the panic. But that’s it.
This is about the only device I’m worried about as part of this transition, as this is the way the family interacts with STHM.
Does anyone have smart recessed lights but not color? I am using the driver for zigbee lights for my light strip & so far so good, but when i went to reset my halo non color recessed light, it took that driver, but there are no adjustments for the different levels of white lighting. The halo light would let me change those.
Im looking for custom Edge driver for 3A Nue zigbee 2,3 4 gang switches and 2 gand GPO outlet.
Currently they are not matching to an edge driver after removing the DTH. Just as a switch with only 1 gang, so loss of function.
( was able to republish this a while ago. But with the recent changes im reluctant to remove the DTH again as im unsure id be abke to republish it.)
Been looking at editing writing my own, after many searches couldnt find one, but wanted to try here, as per the guide at the top details below
