@Mariano_Colmenarejo - Thank you, very much!
I added my remaining Trippers, but they joined as Things - It appears that the problem is that updated driver has not propagated to my hub, it shows that the driver version is still the prior one: “2022-1229T10:05:06….”.
After I noticed this on the first additional sensor, I reset the hub, and then tried adding the remaining sensors, plus re-adding the prior ones, but the hub still has the prior version of the driver, even after rebooting it.
I will check periodically to see if the driver version has been added. When it has, or if it does not within 12 hrs, I will report back here. That said, I am optimistic that they will work as intended once the driver updates on my hub.
Thanks again!!!
