Anyone any news on an edge driver for Nest Thermostat at all?
This will almost certainly come in with Matter support, but will also require a Thread Border Router.
I wonder if this will include the Nest Protect smoke detectors?
I have some Xfinity/Sercomm open/close sensors (XHS2-SE) that I would like to continue to use after Groovy is gone. They can currently work with the Smartsense open/close sensor DTH or the Tyco door/window sensor DTH. I donβt know if these are considered standard or stock device handlers and will be transitioned automatically or I will need to find a custom Edge driver. I have not found a custom Edge driver that has a fingerprint for this sensor. I also donβt know if there is a driver that just needs to have this sensorβs fingerprint added. I have attached images from the Smartthings IDE for this device. Any insights would be appreciated.
Actually Bond made a wifi controller that fit in the ceiling fan shroud that looks and works exactly like the Hampton Bay ZigBee. It is actually what replaced the Hampton Bay controller however it is no longer available at home Depot. I bought my last one on eBay for $40 and sold the ZigBee controller on eBay for $60. It was a definite win win. Should you find one, search for Blueyetisoftware Bond controller driver here and you can have full local control.
As you said, the stock Edge Zigbee contact switch drivers wonβt detect these by direct manu/model fingerprint or by cluster match. Since they work with the smartsense driver, theyβre probably a good candidate to be added to @Mariano_Colmenarejoβs driver.
Added to this driver version
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Contact Mc β
β Version β 2022-09-20T17:53:51.734231849 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
- id: "Sercomm Corp./XHS2-SE"
deviceLabel: Sercomm Open/Closed Sensor
manufacturer: Sercomm Corp.
model: XHS2-SE
deviceProfileName: contact-profile
I couldnβt find these two devices included in any finger print.
Can you please send a link to the driver that you are referring to
Thanks, I did find it in Marianoβs drivers
Looking for a driver for
MSR: 0109-200C-0C02
manufacturer: Vision Security
Raw Description zw:L type:1001 mfr:0109 prod:200C model:0C02
Wow! That was fast! I have to go and try this.
Are you installed this driver versiΓ³n in your hub?
This Thread is only for making a request. Itβs not for discussion about problems with any particular edge driver. Otherwise itβs going to become impossible for other people to read through, including other developers who might want to answer new requests.
Please take any specific discussion of problems or features of a specific edge driver to the author thread for that edge driver. Or you can start a new thread if needed and tag the person youβre talking to. Thank you. ![]()
As a test, I grab one of my 4-buttonsβ¦delete the custom DTH, removed device and tried bringing in again.
no luck with edge driver. I went looking for what is currently listed in fingerprints for buttons/remotes.
many 4 buttons but no
Hank Four-Key controller
Model: HKZW-SCN04
the custom DTH I had was modeled after the aeotec nanomote 4 key. press/doublepress/hold
so I am guessing its only a matter of getting the Device ID in the finger print for it to work with std zwave 4 button events. no?
james
Is there an existing Edge driver for HVAC/thermostat that uses HTTP REST commands?
To port the this DTH for Daikin mini splits that uses the WIFI adapter
Is that something easily feasible/supported natively? Maybe Iβll need to read up on the documentation and Lua.
@TAustin created an edge driver to send HTTP requests to devices on your LAN, so you could certainly use that to interface with the RESTful interface of your thermostat.
Hi Mariano, Thank you for added.
This lock are work sucessfull.
My other yale lock isnΒ΄t work on smartthings, I need repleacement the zigbee module.
Good evening, @Mariano_Colmenarejo could you please add the fingerprint of the zemismart 4-button switch to the Zigbee Multi Switch and childs MC driver, so that each key works separately and that it doesnβt turn on and off all at once. follow the print attachment with the fingerprint of the switch.
Good evening, @Mariano_Colmenarejo could you please add the fingerprint of the 3-button switch from zemismart to the Zigbee Multi Switch and childs MC driver, so that each key works separately and does not keep turning everything on and off at once. follow the print attachment with the fingerprint of the switch.
