Post Requests for Zigbee Edge Drivers Here (community-created)
Minor modifications to drivers is pretty easy after you figure it all out and do the 1st one.
  1. Install the CLI. Use the search function above to find the instructions.
  2. Down load the desired Driver files from GitHub. Google how to download GitHub files.
  3. Use Notepad ++ to modify the file. Free download
  4. Use the CLI to Package, Publish and Install the drivers. This is the not hard but the more involved part.
  5. If you want you can go 1 Step farther and use the CLI to create a Channel for sharing your updated drivers.
As far as eliminating the temperature display. In your finger print file pick a presentation that doesn’t include temperature. There is a separate presentation file in each driver and you just need to select the one you want and include the name with your fingerprints.
