I just stumbled onto a weird bug developing a button controller parent/child SmartApp. Trying to keep track of the toggle state of switches I am resorting to using state to store the status of a switch before controlling it. The problem is that when I call state or atomicState at any point in the event handler the event fires the SmartApp a second time with the same Event ID. If I remove or comment the code assigning values to the state variable, the function is not called a second time.
I added a filter, assigning an atomicState varible to track the last event ID and prevent execution if the event has previously called the function. This fixed the problem, but its a very odd glitch. It’s affecting all child apps, even those newly created.
Anyone else encounter this before?
tgauchat
#2
state is a variable (a collection), not a method or object (I think…) so it isn’t “called”, just accessed.
So I find it odd that using it would cause a new invocation of the SmartApp. But… Well… There’s a lot that has happens under the covers, so I may be overlooking an obvious place a bug could occur…
atomicState performs an immediate read/write operation, so might have different behavior.
Have you been able to reproduce this with a trivial test SmartApp just as proof of concept that anyone could use to see if they replicate the problem?
Commenting or removing these 2 lines prevents the duplicate call. I’m aware of how state functions, but accessing it is causing a the SmartApp to be called a second time.
