Piston state
I read about the state of a piston but I don’t understand how to use it (be patient, I’m not young anymore)
Can you give an example?
Need for debug?
It’s to do with how the piston shows in the dashboard. Normally it shows as true. However, if you disable automatic piston state, you can use it to display information about the piston such as variables or text.
Here are some of mine show in the dashboard
Here’s a snippet of that fan control piston with the piece that sets the piston state. BTW, FanOnReaon is a variable.
Hope this helps.
OK, thank you …
