Phillips hue/ST integration bug
@jdroberts is correct.
This is how I would do it.
  • Create one virtual switch called dining room lights.
  • authorize Alexa in the ST app to control this VS
  • create a rule in rule machine like this:
Condition: VS on
Rule: VS on
Actions for true: turn on (choose all of your lights here). Run custom command - refresh()
Actions for false: turn off selected lights, run custom command - refresh()
This allows you to control each bulb individually via Alexa. It also allows you to turn ask if them on/off via Alexa or ST at once.
Note - if you chose “set these dimmers” in the actions for true instead of “these switches” you can set a dimmer level for the lights to come on.
So if you already ththem at 100% when you turn them all on, then they will if you chose that option.
Another solution I use is I have a cooper stick on switch that controls my master bedroom fixture with 4 hue white bulbs. This has instant reporting. I se the dim with me smartapp to link up the 4 bulbs to to the master dinner cooper switch. I remove the individual bulbs in Alexa and when I tell her to turn on the master bedroom lights. She turns the switch on and it and the bulbs update status immediately in smart things.
Just thought I’d throw in my experience. Maybe someone could point me in the right direction…
I’d be OK with ST getting back in sync with a poll every 5 mins. The problem is that this doesn’t seem to be the case. If I control a Hue light with a Hue remote, then ST never gets in sync. It’s almost as if it’s not polling to get the latest state…?
If I go to “My Home” in the iOS app, it will tell me that some bulbs are on when they’re not and visa-versa. If I pull down on the screen to force a re-fresh (a bit like you can do with an email client to get it to sync your mail) I would expect that to force a re-fresh, but it doesn’t.
