It’s battery operated, so not quite a match, but the SmartenIT 3 toggle switch makes a nice wall switch in the SmartThings verse. Using the community-developed device handler you can assign zwave devices, zigbee devices, hello home actions, or custom code to it.
This code stopped working with the 2018 version of the SmartThings app. The device should no longer be considered compatible.
Yes, Virginia, there is a battery operated toggle switch that looks like a regular switch and can be used to change modes, run Hello Home Actions, or toggle one or more devices on and off! It does have 3 toggle “buttons” instead of just 1, which some people will see as a negative, but it’s a very nice device. It can be mounted on the wall anywhere, it does not require any wiring. Or it can just lie flat on a table.
It’s zigbee, but because SmartThings supports both zigbee and zwave, that doesn’t matter, you can still use it to control any of the devices you control through SmartThings.
You can also easily feel the separations between the three toggles, …
