Panos
(Panos)
1
Hello.
I want to write a smartapp to get same data from a local server and pass these on DH.
When I trying with the code below:
def params = [
uri: "10.0.10.10:8080"
try {
httpGet(params) { resp ->
def data = "$resp.data".toString()
log.debug (data)
Am getting the following error:
something went wrong: java.lang.SecurityException: Endpoint http://10.0.10.10:8080 is blacklisted.
After browsing the web, I found that ST hub prevent this action because the web server is a local IP address and not external.
Is there any workaround or an alternative method to get the requested data from the local web server?
Thanks.
Panos
(Panos)
3
Hello.
Thanks for your replay.
After modifying the code to:
def Host = "10.0.10.10:8080"
sendHubCommand(new physicalgraph.device.HubAction("""GET HTTP/1.1\r\nHOST: $Host\r\n\r\n""",physicalgraph.device.Protocol.LAN, null, [callback: cbk]))
void cbk(physicalgraph.device.HubResponse hubResponse) {
log.debug "Entered calledBackHandler()..."
def body = hubResponse
log.debug (body)
The response is:
… 19:11:14: debug Entered calledBackHandler()…
… 19:07:44: debug physicalgraph.device.HubResponse(index:BF, mac:B827EB7B760F, ip:0A000A1D, port:1F90, requestId:52ab43e5-eac2-41e3-ae7a-1fad9f47ea7a, hubId:edb6007d-322b-43e2-bcde-924d5175d1ff, callback:cbk)
Normally I should get these HTML data as a response:
ZP1B Sensor Data
data1: 11111
data2: 2222.2
data3: 33.3333
I can’t figure out how to save the responsed html data to variable “body”
RBoy
4
A simpler way:
def hubAction = new physicalgraph.device.HubAction(
method: "GET",
path: "",
null,
[callback: callbackParse]
sendHubCommand(hubAction)
void callbackParse(physicalgraph.device.HubResponse hubResponse) {
log.debug "Body: ${hubResponse.body}"
Panos
(Panos)
5
Unfortunately i cant make it to work.
I got an "java.lang.NullPointerException: Cannot get property ‘id’ on null object” error.
Is it possible to share a sample code please?
I want to make the get requests towards 'http://10.0.10.10:8080”
–EDIT–
I was able to make it work:
def sendCmd(evt){
def deviceIP = “10.0.10.10"
def cmdStr = new physicalgraph.device.HubAction([
method: "GET",
path: "",
headers: [
HOST: "${deviceIP}:8080"
null,
sendHubCommand(cmdStr)
def data = hubResponse.body.toString()
log.debug (data)
Thanks guys for the help
