Hi all!
Are you able to control Particle (Photon) via SmartThings app (new)? I have modified DH that works pretty well in Classic app. In new app it shows as disconnected contact sensor.
DH is included. Any help appreciated.
* GarageControl edited by Davor
* Copyright 2018 by Jared Shearer
* This SmartThings device handler integrates a Particle (Photon in my case) with a Relay Shield with SmartThings
* to open and monitor the state of garage doors.
* A WebCoRE piston calls the refresh() function to update the door statuses in SmartThings when a state change
* is published from the Particle Sketch.
// user input preferences
preferences {
input name: "deviceId", type: "text", title: "Device ID", required: true
input name: "token", type: "password", title: "Access Token", required: true
input name: "contactVar", type: "text", title: "Contact Variable Name", required: true, defaultValue: "GarageStatus"
// name the capabilities app author etc
metadata {
definition (name: "Status garaznih vrata", namespace: "Davor", author: "dibriks") {
// capability "actuator"
capability "contact sensor"
capability "Switch"
capability "Polling"
capability "Sensor"
capability "Refresh"
attribute "Status", "string" // Defines a container to hold the state of your garage door
command "garageRelay" // Defines a command to trigger the garage door we want opened
// make the tiles for the device handler
tiles {
standardTile("contact", "device.contact", width: 2, height: 2) {
state "Open", label: '${name}', action: "garageRelay", icon: "st.Transportation.transportation12", backgroundColor: "#44b621"
state "Closed", label: '${name}', action: "garageRelay",icon: "st.Transportation.transportation14", backgroundColor: "#bc2323 "
state "In motion", label: '${name}', action: "garageRelay", icon: "st.Transportation.transportation13", backgroundColor: "##e86d13"
state "Ventilation", label: '${name}', action: "garageRelay",icon: "st.Weather.weather10", backgroundColor: "#153591"
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 1, height: 1) {
state "", action:"refresh.refresh", icon:"st.secondary.refresh"
main(["contact"])
details(["contact", "refresh"])
// Refresh value
def refresh() {
log.debug "Executing 'refresh'"
//execute get value command on refresh
getvalue()
// Get value of contact sensor variable from particle
private getvalue() {
def closure = { response ->
log.debug "Contact request was successful, $response.data"
// This is the line that sends the contact sensors response value of either open or closed to the contact sensor
sendEvent(name: "contact", value: response.data.result)
// part that gets sent to particle to get the value of the variable
httpGet("https://api.particle.io/v1/devices/${deviceId}/${contactVar}?access_token=${token}", closure)
def contact() { // This is what happens when tile contact is pushed.
log.debug "Executing 'garage1'"
put 'open' // Calls put(garageRelay) and sends it a "pokreni_otvaranje" which tells the Particle sketch to run GarageRelay with command == open
def garageRelay() { // This is what happens when tile g1Status is pushed.
put 'open' // Calls put(GarageRelay) and sends it a "1" which tells the Particle sketch to run GarageRelay with command == open
// How we push commands from the device handler to the Particle
private put(garageRelay) {
log.debug "sending post";
httpPost(
uri: "https://api.particle.io/v1/devices/${deviceId}/GarageRelay",
body: [access_token: token, command: garageRelay],
) {response -> log.debug (response.data)}
log.debug "post sent";
