I have a Samsung heat pump/boiler, that i can see in my Smartthings app. I also have an electricity meter with a P1 port. Via this port i can see when i have too much solar energy that is sent to the Grid. When this happens I would like to start the boiler to heat up the water.
Is there a P1 reader that Is detected by Smartthings? There are Zigbee P1 meters ( such as Electricity Meter Interface 2, P1 ) . Can SmartThings can use the energy data in automations (not just display it)?
if possible I would like that the setup does not require a local hub, but is based on configuration in the Smartthings app.
