Outdoor Lights - turn on dimmed at dusk, full brightness for X minutes when motion detected
EDIT: I started a new thread proposing a ‘final’ version of this. Link
There’s got to be a more efficient way to do this. . . . well, anyway, here is the latest code that should work around the iOS bug. I also applied what I learned from this to make the selection of the delay time from a list instead of a numeric entry.
The code. Version 3:
 *  Dusk-to-Dawn Motion/Dimming Light - AaronZON - Dev Branch V3
 *  Copyright 2014 Aaron Herzon
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
definition(
    name: "Dusk-to-Dawn Motion/Dimming Light - AaronZON - Dev Branch V3",
    namespace: "AaronZON",
    author: "Aaron Herzon",
    description: "Dusk to dawn light with dim/bright motion sensing ",
    category: "Safety & Security",
    iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
    iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
    iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
	section("Select Motion Sensor(s) you want to Use") {
        input "motions", "capability.motionSensor", title: "Motions", required: false, multiple: true
    section("Select Dimmers you want to Use") {
        input "switches", "capability.switchLevel", title: "Switches", required: false, multiple: true
    section ("Set Bright and Dim Levels") {
		input "DimLevelStr", "enum", title: "Dimmed Level", required: true, options: ["10","15","20","30","50","75"]
        input "BrightLevelStr", "enum", title: "Bright Level", required: true, options: ["100","75","50"]
        input "DelayMinStr", "enum", title: "Bright time, minutes", required: true, options: ["1","3","5","10","15","30","60"]
    section ("Zip code (optional, defaults to location coordinates)...") {
		input "zipCode", "text", required: false
    section ("Sunrise offset (optional)...") {
		input "sunriseOffsetValue", "text", title: "HH:MM", required: false
		input "sunriseOffsetDir", "enum", title: "Before or After", required: false, options: ["Before","After"]
	section ("Sunset offset (optional)...") {
		input "sunsetOffsetValue", "text", title: "HH:MM", required: false
		input "sunsetOffsetDir", "enum", title: "Before or After", required: false, options: ["Before","After"]
def installed() {
	log.debug "Installed with settings: ${settings} DelayMin: $DelayMin"
	initialize()
def updated() {
	log.debug "Updated with settings: ${settings}  DelayMin: $DelayMin"
	unsubscribe()
	//unschedule handled in astroCheck method
	initialize()
def initialize() {
	state.DimLevel = DimLevelStr as Integer
    state.BrightLevel = BrightLevelStr as Integer
    state.DelayMin = DelayMinStr as Integer
    subscribe(location, "position", locationPositionChange)
	subscribe(location, "sunriseTime", sunriseSunsetTimeHandler)
	subscribe(location, "sunsetTime", sunriseSunsetTimeHandler)
    subscribe(motions, "motion.active", handleMotionEvent)
    subscribe(motions, "motion.inactive", handleEndMotionEvent)
	initialSunPosition()
	astroCheck()
def locationPositionChange(evt) {
	log.trace "locationChange()"
	astroCheck()
def sunriseSunsetTimeHandler(evt) {
	log.trace "sunriseSunsetTimeHandler()"
	astroCheck()
def initialSunPosition() {
	//Determine if sun is down at time of initializtion and run sunsetHandler() if so
	def s = getSunriseAndSunset(zipCode: zipCode, sunriseOffset: sunriseOffset, sunsetOffset: sunsetOffset)
	def now = new Date()
    def riseTime = s.sunrise
	def setTime = s.sunset
	log.debug "riseTime: $riseTime"
    log.debug "setTime: $setTime"
    log.debug "Now: $now"
    	if(setTime.before(now)) {
	        sunsetHandler()
            log.info "Sun is already down, run sunsetHandler"
	    else
        {	if (riseTime.after(now)) {
        	sunsetHandler()
def astroCheck() {
	//query sunset and sunrise times with offsets applied, schedule handlers for sun events
    //this method lifted from Sunrise/Sunset with some mods and error corrections
	if (state.riseTime != riseTime.time) {
		state.riseTime = riseTime.time
		unschedule("sunriseHandler")
		if(riseTime.before(now)) {
			state.riseTime = riseTime.next()
        log.info "scheduling sunrise handler for $state.riseTime"
        //todo: resolve issue with date formated as Epoch sometimes in log
		schedule(state.riseTime, sunriseHandler)
	if (state.setTime != setTime.time) {
		state.setTime = setTime.time
		unschedule("sunsetHandler")
	        state.setTime = setTime.next()
        log.info "scheduling sunset handler for $state.setTime"
	    schedule(state.setTime, sunsetHandler)
def sunriseHandler() {
	log.info "Executing sunrise handler"
    switches?.setLevel(0)
    state.sunPosition = "up"
def sunsetHandler() {
	log.info "Executing sunset handler"
	switches?.setLevel(30)  //starts at 30 (arbitrary) to make sure lights start (my LEDs won't start at below 20% but run fine)
    state.sunPosition = "down"
    runIn(3, dimOrOffafterBright)  //after initial light-off, runs handler to set to selected dim level after 3 seconds
def handleMotionEvent(evt) {
	log.debug "Motion detected . . . ."
    if (state.sunPosition == "down") {
    	switches?.setLevel(state.BrightLevel)
        state.Level = state.BrightLevel
    	log.debug ". . . set the dimmers to level $state.BrightLevel"
    else
    	log.debug ". . . but sun is up, so do nothing"
        log.debug state
def handleEndMotionEvent(evt) {
	log.debug "Motion stopped . . . ."
    	switches?.setLevel(state.BrightLevel)  //does nothing unless sun went down during active motion
    	log.debug ". . . set the dimmers to level $state.BrightLevel if not already there"
        runIn((state.DelayMin*60), dimOrOffafterBright)  //delay is number of minutes entered in preferences x 60 to get seconds
    else
        log.debug state
def dimOrOffafterBright() {
	//Handles the case where the sun comes up during bright time
	log.debug "Bright delay is complete, decide to turn off or dim based on sun position and offsets"
    	switches?.setLevel(state.DimLevel)
        state.Level = state.DimLevel
    	log.debug "Return to dimmed states since sun is down"
        log.debug state
    else
        state.Level = 0
        log.debug "Turned off lights since sun came up during bright time"
        log.debug state
private getLabel() {
	app.label ?: "SmartThings"
private getSunriseOffset() {
	sunriseOffsetValue ? (sunriseOffsetDir == "Before" ? "-$sunriseOffsetValue" : sunriseOffsetValue) : null
private getSunsetOffset() {
	sunsetOffsetValue ? (sunsetOffsetDir == "Before" ? "-$sunsetOffsetValue" : sunsetOffsetValue) : null
