Hello, I am having an issue with my new Osram RGBW bulbs. For some reason my Echos are not discovering the bulbs. Has anyone experienced this issue?
You’ve probably already done this, but just to be sure, see step 10 in the community setup FAQ. You have to individually authorize each device to be available to echo before it will be able to see it.
NEW: Alexa IFTTT Triggers
As of November 12, 2015, there are now two official ways to integrate Alexa and SmartThings.
The first way is fast and simple, and can do any one thing that you can do in the official SmartThings IFTTT channel.
You pick any phrase you want to use, and use that as the “if” in the Alexa channel at IFTTT for a new recipe. Then you just pick from the dropdown options in the SmartThings IFTTT channel as the “that.”
To use a recipe, you say “Alexa, trigger {my phrase}.”
So you could say “Alexa, trigger open the pod bay doors” to open your garage door, “Alexa, trigger autodestruct” to turn on your siren, “Alexa, trigger kitchen lights” to turn on your kitchen light. Whatever you want. This is the power of IFTTT, and why SmartThings having a channel there is so u…
