I have a mid 1960’s condo and it has no overhead lighting. However, in both rooms the wall switches control the top outlet on specific outlets.
The one I’m looking at is in the bedroom. I was looking to possibly put a smart switch in, but I’m not sure if there’s a neutral wire in the bundle.
However, to my surprise (and I assume lack of code since 1969), there is no ground on the switch.
I pulled the switch from the wall and there are 2 wires connected to it. One looks white with a black stripe (bottom screw) and the other looks black (or blue hard to tell).
The white one looks like it goes into a wire nut which meets a couple wires and goes down. The black/blue wire seems to go straight up into the ceiling (i assume this connects to the outlet on the far end of the room).
There is however, a wire nut in the back with two white wires in it. One of them goes down, and the other other up (neither is connected to the switch in any way). What exactly is this wirenut? I didn’t see any obvious ground. The switch itself has only 2 wires.
I was looking to possibly have an electrician install these, but if I don’t have a neutral, it’s probably a lost cause and don’t want to waste his time. I do have a multimeter, so I can test anything.
Was just curious how to know if it’s neutral or not before I go splurging on attempting a smarthome.
