jkp
April 26, 2022, 7:49pm
16
You may want to check out an Edge Presence sensor at this point (if your hub supports Edge). Groovy device handlers will be phased out at some point in the future.
Here is an Edge driver that will enable end-users to create virtual devices that run locally on-hub.
UPDATED JULY 2023…
Features:
Supports the following virtual device types:
A/C, air quality, alarm, Alexa switch, battery, CO2 level, contact, door, energy, fan, garage door, illuminance, Level/dimmer-only, lock, light (including RGBW), momentary button/doorbell,
motion, panic, presence, refrigerator, smoke detector, sound pressure, sound sensor, switch, switch level/dimmer, temp/humidity, TV, thermostat, video camera, water sensor, window shade
Create any number of virtual devices
Easy and fast to use: No coding or CLI required
Enables you to create 100% local automations with virtual devices
See how many devices you’ve created of a given type (inventory)
Devices include additional …
