The Smart Lighting app is missing key features still, like LUX value being used to determine if an automation should run.
Been using this on and off for a while, but only looked at it seriously with the seasonal weather change necessitating some changes to my setup. Iâve come to realize this is an amazing piece of work! The âsimpleâ part is really misleading because although it is simple to use, it is by no means simple in the complexity of rules you can set. With the AND/OR conditionals, I was able to create quite a specific automation that would have taken at least three instances of a smartapp to accomplish.
Itâs really amazing though that this is not part of the native app.
When you use this, is there any kind of a noticeable delay? Like with IFTTT?
No this is tied directly into SmartThings. It is as far as I understand a native SmartApp.
Thanks, Iâll give it a try.
Hi @JoeC and other SimpleRuleBuilder users⌠I upgraded to the v2 hub and right after I reconnected the web service I started having problems. Has anyone else had this? I donât know if SRB is the culprit or not but I removed my account just to be sure and reset my hub, and since then all is better - at least for now. Time will tell since the problem was intermittent. Anyway, has anyone else had this problem? I describe it in detail toward the tail end of the Harmony thread here:
Thanks all.
Edit: I should have mentioned that I was a user with the v1 hub and used the âmigrate to v2 hubâ feature on the SRB website.
This is really great ! Thanks for building this !
Any possibility to add sunrise/sunset ? (this would enormously help with controlling lightingâŚ)
Thanks again !
I think I get what youâre trying to do - the way I did that is by creating a couple of routinesâŚWhen the sun rises (letâs call it Good Morning), it sets the mode to âDayâ, and when the sun sets (letâs call it Good Evening), it sets the mode to âNightâ. Once you have this Day and Night modes, you can easily build a rule in Simple Rule Builder to trigger in specific modes only like Day and Night triggered by the routine. Hope this helps!
did you ever get this to work i have a virtual switch that i can get to show up at all??
thanks
I just tried this out, but I got this failure when attempting to install the SmartApp (v2 hub in US). This error happened after I clicked [Authorize] after selecting a location and some things.
Server Error in â/â Application.
The remote server returned an error: (500) Internal Server Error.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[WebException: The remote server returned an error: (500) Internal Server Error.]
System.Net.HttpWebRequest.GetResponse() +6542104
SmartThingsRuleBuilder.AccountSetup.getAccessToken(String OAuthCode) +418
SmartThingsRuleBuilder.AccountSetup.Page_Load(Object sender, EventArgs e) +238
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +51
System.Web.UI.Control.OnLoad(EventArgs e) +92
SmartThingsRuleBuilder.App_Code.BasePage.OnLoad(EventArgs e) +37
System.Web.UI.Control.LoadRecursive() +54
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +772
I now see the âSimple Rule Builderâ SmartApp, but I canât get past the AccountSetup.aspx page at simplerulebuilder.com.
My guess is that SmartThings implemented the changes to their OAuth process they were talking about. Iâll take a look at it this weekend, sorry for the inconvenience.
(Thereâs no inconvenience and no need to be sorry!)
They havenât (yet).
Just one of their 3rd party libraries now wonât work with âGETâ for tokens â you need to use âPOSTâ. See the online documentation for the updated OAuth flow.
Hi Iâm having an issue with the Simple Rule Builder and a Z-Wave tilt sensor. Specifically http://www.amazon.com/gp/product/B00OJMKO24?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
The device is connected probably to the Hub and I can access it directly from the SmartThings native apps. It looks good as well in the graph api site and I do get native alerts. When I click on the device in the Simple Rule Builder, it doesnât show a status of open or close. It shows nothing under the Current Values section. Any help would be deeply appreciated. Iâm trying to set up a rule to send me a push notification at a specific time if the sensor status is open. Thanks!
Does or will SRB support momentary switches? Iâm working on the amazing Alexa Helper integration and being able to have SRB control my Nestâs via a virtual momentary switch would be awesome.
Yes I know I could also just use a normal on/off virtual switch but I like the idea of not worrying about a switchâs state in order to toggle my Nest from Home to Away.
Any help on this would rock. Thanks.
I just signed up, had some trouble and then signed up again. Now I get the following error message. Any idea how I fix this?
There was an error retrieving some of your location data. Maybe you have multiple modes or routines with the same name (or no name). Or maybe you have another simplerulebuilder.com account?
Debug data:
Type: HelloHomePhrase
Debug data:
Debug data:
Debug data:
Debug data:
Type: Mode
Debug data:
Type: Mode
Debug data:
Type: Mode
Debug data:
Type: Mode
Thanks,
Matt
It doesnât like when you have two accounts for one hub. (I know, I shouldnât let you even do that if it doesnât like it). I deleted your other account, give it a try now.
Perfect. I don;t even know how I got the two accounts. Thanks so much for doing this!
Matt
