I am sorry, I am stuck here. I have the App ID and Access token (using the SmartApp Method) however I am not seeing Additional Requirements or where to enter the IDs to complete this step.
Itâs the very next step in the guide after the bit you quoted?
But arent you using Plex Manager for polling? Or are you now using the exe? You only need to configure this if configuring the exe (a seperate application that needs to run on a computer)
That was what i wasnât following. So if I am only using the app via ST I do not need the OAuth step?
Correct as I said in my earlier post you just need to add the media player device below the IP address box
I set up a room so that when I pause it turns the light in that room back on. I used this as a monetary option. However the input is slow to run the command and turns the light on and off within a sec I stead of leaving it on when paused and off when play.
The delay is likely to be caused because you are using the Plex Manager, this polls every 10 seconds for a change of state, so it could be up to 10 seconds before anything happens⌠the only way to avoid this is to adjust the polling in Plex Manager (not advised) or if you are running Plex server on a computer then move to the EXE approach aboveâŚ
For the momentary option, I think you are using it incorrectly? This is meant for instances where scenes are triggered via a switch, momentary switches by their very design only go on briefly then back off, as they a momentary⌠if you just want to turn lights on then move the lights to either âSwitches off when playingâ which by default turn on when paused⌠or âadjust level of these bulbsâ/âAdjust level and color of these bulbsâ and specify the âLevel On Pauseâ
However sounds like you may already have the pause value set, which is why you are seeting them come on then shortly after go off
Hope that helps!
Pulling this in via the github integration.
Lower case was created successfully but the upper case failed (no given error):
smartapps/jebbett/PlexPlus.src/PlexPlus.groovy
Is the lower case one (plexplus.src/plexplus.groovy) the right one to use here?
Yeah use the lowercase only, when I saved initially it was in uppercase which was incorrect as ST pushes updates in lowercase and the whole thing gets confused
Yes this is very helpful thank you for explaining momentary states. One question I have a WeMo switch that turns on the sub so essentially onice Plex starts I want to turn on The WeMo switch but I do not want to turn off when itâs paused. I know you donât have a stop command but essentially I want to leave the sub i.e. the WeMo switch on unless Plex is stopped. Is this possible?
Assuming you are controlling your bulbs state using the bulb % settings and not switch settings, then just put it in as a switch and turn on âSwitches use Play config when Pausedâ.
That should do the job
If for whatever reason you need to keep that setting then the other option is to create another room with the same trigger, but different settings⌠the apps designed to be fairly flexible
Oh no, i cant because the bulbs i am using is a switch not a bulb (it is a fan). So i have to use the switch option.
Thatâs fine so just create another âroomâ as per my second suggestion
Just another hint as well, Iâd put a long stop delay on the sub to stop it turning off then on between TV episodes or queued films
Updated Plex Plus to support Plex Webhooks (Plex Pass Only)
This allows Plex to directly send status updates to SmartThings, this bypasses the need for the Plex2SmartThings program.
Update your Plex server first!
App now at V3.1
https://support.plex.tv/hc/en-us/articles/115002267687-Webhooks
Hello,
I went through your instructs on how to setup Plex Plus to work with Plex. Iâm also using the Plex2SmartThings app as well. With Plex adding Webhooks support, how do I utilize that in your app since youâve added the support? Does Plex2SmartThings still need to be used if using Webhooks?
Thank you for any advice you can provide.
Thanks,
Tom
Hi Tom,
WebHooks is an alternative to the Plex2SmartThings program, basically the program did pretty much what webhooks does, and because you donât require a seperate program it is a better way of doing it!
The only thing to note is that you canât use IP address as webhooks doesnât provide an internal IP address unfortunatelyâŚ
If you are not using IP address then setup should be as simple as pasting the webhooks URL in to Plex and closing Plex2SmartThings! Please ensure your server is also up to dateâŚ
New version live:
v3.2 - Updated Live Logging to be able to get Plex2SmartThings setup details easier, Cosmetics for WebHook and addition of matching 2 criteria, which I am now using where I have two of the same Samsung model TVs, but they have a different user on eachâŚ
EnjoyâŚ
This is awesome. I set it all up last night using Webhooks and it works great.
One question: Is it possible to add more details to the virtual devices (i.e. track name, artist, etcâŚ)? I canât think of any practical reason to do it but I think it would be cool
Itâs definitely possible especially if you are using webhooks, this makes it really easy!
But like you say Iâm not sure of the value it would provide⌠in most cases you donât even need the virtual device if you are doing the lighting in Plex Plus⌠personally I try to keep out of the smart things app where possible because itâs so slow doing anythingâŚ
However if I have time on Sunday or while Iâm at work next week see if I can add it as an optionally enabled function
