Please remove your devices, take both child and parent handlers and perform zigbee join.
I added the fingerprint for your device, it should be discovered automatically.
After this, you should be able to configure the number of child devices in the settings.
Cheers,
Yakov
Groovy which is based on Java has the same considerations on processing,
If future code will need multi conditions an if/else statement would be the approach to go, but if youâre only trying to evaluate one condition (something =? X) the switch statement is faster processing wise as the JVM loads the values of the âcasesâ into a table and iterates through them without doing for example a mathematical comparison (âis 2+2 = 4 ?â).
Interesting that the zbjoin that @b16b doesnât have more than one endpoint, which means if its a 3-gang switch, the buttons are inside the same EF00 command structure (or non consecutive endpoint numbers).
Thank you for your clarifications.
Thatâs an interesting insight, even though I believe the difference wouldnât be noticeable for cloud environment.
Tuya implements proprietary protocol on top of 0xEF00 cluster. From what I understand
all messages are sent to destination EP =1
the format of the message is as follows: DPID 1 byte type 1 byte
0x00 raw
0x01 bool
0x02 uint32 (big endian)
0x03 string (N bytes)
0x04 enum 1 byte
0x05 bitmap 1/2/4 bytes len 2 bytes (in big endian, 01FF would mean 511 dec) value 1/2/4/N
DPID is basically a kind of proprietary endpoint inside Tuya cluster.
Please take it with a grain of salt, Iâm new to this stuff
thanks for your fix⌠i create the 3rd switch from the settings but the 3rd gang is always on and does not workâŚ
i think
you must change some of the code
207 line add
case 3: // Switch 3
247 and 262
cmds += createChildOnOffCommand(3,true)
cmds += createChildOnOffCommand(3,false)
279
zigbee.readAttribute(zigbee.ONOFF_CLUSTER, 0x0000, [destEndpoint: 0x03]) + // switch 3 state
hub recognise the switch as a thing a must change it from ide
and
main relay parent open and turn off when every gang is turn offand turn on if is at least one is turn on
but does not follow the gang 2
also as switch does not turn on or off, still loading when tap it
maybe the reason that does not work as parent switch is the gang 2
Regarding zigbee join, this is what needed as a text, not image. I already added a fingerprint from this post and if that doesnât work I probably have typo somewhere. Therefore, please post it as s text, so it could be copy&pasted.
Regarding the second issue, please provide logs as a text, not image.
Thank you
Also, could you please provide a link to your product?
In your log I see messages that I donât know how to decode. It could be related to some additional functionality your switch has
