[OBSOLETE] Hue (Re)Connect - with scene handling
I had some trouble getting this to work until I copied and pasted from the “raw” code in github. When I first tried to install, everything seemed to work but turning things on or off did nothing. I don’t know, this just might be coincidence but I tried three times and I finally got things to work when I did that.
BTW, fantastic work incorporating the Hue scenes into ST. This makes it 10X better being able to automate everything so easily in ST. Now, when I tell Alexa to “Turn on the TV”, she turns on the power to my media center, then she connects to my harmony hub and turns on all the correct devices that go with my TV, and finally, a routine is executed that turns off lights and switches on a hue scene for watching movies. My final puzzle is to figure out how to turn on my Mac Mini that I use as a media player. The Mac Mini has an electronic “ON” button that requires a physical press to make it work. I think I’m going to try a push solenoid that is connected to a smart outlet to accomplish that task.
Update: Well I got it to work with my Mac Mini turning on using a push solenoid and several apps:
