Is there updated version coming soon? Please advise
UPDATE
Please update your parent and rooms apps to the most current version.
This release features bug fixes for the following:
- Color bulb control - corrected a bug in which single bulb commands were actually controlling all bulbs in the room
- Temperature feedback - Corrected âNullâ response when asking âWhatâs the temperatureâ
- Humidity feedback - Corrected âNullâ response when asking âWhatâs the humidityâ
Thank you for your continued support and please continue to report any issues that may arise.
Community installer shows updates for rooms child app (rev 0.0.6) but not for the parent app (showing 0.0.2).
Thatâs fine. Donât worry about the parent app.
Greetings to all:
I need your help. While configuring EchoSistant in my iPhone X, after converting the Auth Code, I am getting error message saying âUnable to find a Valid VendorIDâ. And I am stopped here from installing rest of the parts. Could you please help? Tito
I havenât seen that error before, Iâll look into it.
Did you register your Amazon account first?
Hi Bamarayne: Thanks for quick response. I created Amazon account already. It was my mistake. I used one of my two amazon accounts that has no Alxea registered. Later I used the account which has Alexa device registered. Now, I have completed the installation. Going to test now.
Do you think using Amazon account with no Alexa registered could cause error the one I had? if so, that is my lesson learn. Thanks again, Regards Tito
Hi Tito,
Iâm not sure what caused it. I would need to see the logs. I was just testing and i did get an error if there were not any rooms created, but it was a different one.
Iâm glad you got it installed. Let me know if there is anything else.
Hi Bamarayne:
Just created one room and tried to operate EchoSistant. When I say âAlexa trun off office room after 1 minuteâ, but the Office Room is turned off instantly, no delay. Could you please advice how to debug?
I did not find any information on how to install âEchoSistant Logic Blockzâ and âEchoSistant Roomsâ but I installed them under my SmartApps manually. Was I right?
Thanks for your kind help.
To make this work you would say, âAlexa, in one minute turn off the lights in the officeâ.
Have you read through the wiki?
Thanks. No, I did not go through the wiki. I will do this evening.
Sorry to bother you againâŠI said âAlexa, in one minute turn off the lights in office roomâ. Alexa responded âOK, I will in one minute turn on the office room lightsâŠâ but the light turn on instantly.
Say this, âturn the lights on in one minute in the officeâ
Thanks. Working!!!
Many many thanks
Glad thatâs workingâŠ
Did you know that you can also do thisâŠ
Alexa, turn the lights on for 10 minutes in the office
The lights will immediately turn on and then turn off in ten minutes.
I have been out of town for a number of days, and when I got home I went to turn on the lights and the lights came on when I said âAlexa turn on the lights in the living roomâ but the followup from Alexa said âyour message has been sent to living roomâ Prior to I would always reset the queue and it would work and that message sent to xxx would stop. But not now. Any ideas on why this keeps happening?
The queue has nothing to do with EchoSistant. That is all Echo Speaks. EchoSistant is only sending that command to Echo Speaks for processing.
As for the message being sent instead of the command working properly I need to see the logs.
Have you changed the code in any way at all? Are you up to date on all of your code? The latest updates had nothing to do with what you are talking about happening. But at any rate, show me the logs.
No havenât changed the code and I have the latest. Below is the log.
Here is the piston log for speaking.
I need to see the log for the family room.
