I am implementing OAuth 2.0 Authorization Code Grant for my API_ONLY/OAuth-In App created via the SmartThings CLI. The initial OAuth flow works: my server receives the authorization code, exchanges it for an access token and a refresh token, and I can use the access token to make successful API calls.
The problem:
Whenever my server attempts to use the refresh token to obtain a new access token (using the correct client_id, client_secret, and redirect_uri), the SmartThings token endpoint always responds with HTTP 401 and the following error:
{“error”:“invalid_grant”,“error_description”:“Invalid refresh token: ”}
This happens immediately, even on the first refresh attempt after the initial token exchange.
I have confirmed that my code always uses the latest refresh token provided by SmartThings.
The access token works for API calls until it expires; only the refresh fails.
What I’ve tried:
Repeated the entire OAuth flow with new apps and new tokens.
Verified that all parameters (client_id, client_secret, redirect_uri, refresh_token) are correct and match the app registration.
The issue is consistent and reproducible.
Questions:
Is there an additional approval, publishing, or enablement step required for API_ONLY/OAuth-In apps to support refresh tokens?
Is this a known issue or limitation for new API_ONLY/OAuth-In apps created via the CLI?
Is there a workaround or recommended process to enable refresh token support for new integrations?
Any guidance or help would be greatly appreciated, as this is blocking my integration.
Thank you,
Randy
