I have a webhook endpoint setup as a cloud connector. After auth the system receives a discoveryRequest and sends devices on the response but smartthings is not sending the stateRefreshRequest.
I am not getting a interactionResult so i guess the response for discovery should be fine. When I check on the smartthing app it shows checking… under the device. Is there something that I am missing.
Regarding the issue about the device that always shows in Checking…, it will get fixed whenever the device changes the state for the first time.
Regarding the other issue, I’ve been trying to replicate it but couldn’t make it. I always recieve the stateRefreshRequest. Make sure your connector is handling the stateRefreshRequest properly, and if you’re using the st-schema-nodejs SDK you can configure it as follows:
.stateRefreshHandler((accessToken, response) => {
for (device of devices) {
response.addDevice(device.externalDeviceId, device.states);
Hi @andresg
I have a webhook endpoint in java which handles the request sent by smartthings.
switch (interactionType) {
case discoveryRequest:
// handle discovery
case stateRefreshRequest:
// handle state refresh
case integrationDeleted:
// handle unlink
case commandRequest:
// handle command
case grantCallbackAccess:
// handle grant callback
I am receiving other requests but couldn’t get the stateRefreshRequest. I even configured a different project for testing and production but couldn’t receive stateRefreshRequest on both of them.
