Is anyone else seeing this error when they try to load and run an existing custom device type in the IDE? Also happens when I create a new custom device type from scratch.
groovy.lang.MissingPropertyException: No such property: type for class: physicalgraph.group.cassandra.Room
Possible solutions: name
I cant find any information on this I bet I need to define a new parameter for the new Room feature. My device types ran just fine up to yesterday?? Also my list of physical devices is gone I cant select a device to run my custom device type against. @Dianoga
Iām still getting the error as well. Any updates on when this will be fixed? I understand a patch is out but it didnāt appear to have accomplished anything.
Seems about right. I was on a plane trying to update my custom device (Thursday) and I thought the errors were due to a crappy connection. The only way around it was to keep going back out to the āmy device tabā and then click back on the device. That was the only way for me to run the sim.
Ahh good suggestion Patrick! So it still works if you save and publish? I guess I can assign it to a device by editing the device under the my devices section and assigning it there. Thanks!
No Joy⦠Support has seen this thread and they are working on it but there is no timeline. However @JohnR, for me smartapps are fine but device types, none is working,
Still no updates? Iām not getting errors anymore but instead I canāt get past the install part⦠just hangs if I try to connect to my ārealā physical devices. Virtual devices install and work fine⦠but the real devices show the spinning donut
