New to Smartthings and would like to know how to get echo to work with linear garage door opener
Actually the problem was not with deleting and reinstalling the app. It fixed it this time because that particular bug was fixed.
Following the directions provided is extremely important.
We can not help if you do not answer the questions we all and if you do not follow the directions as written.
not to muddy the waters here. but i didn’t have to use alexa helper to get my garage working. is it because i just set up an open and close routine?
Well, if you go back to the beginning of this thread, I told you then you didn’t have to use Alexa helper. You were told you had a choice. You actually don’t even need the two routines you setup.
I took about 20 minutes and tired out the exact steps you needed to take to make it work without routines and without Alexa helper.
So, just done friendly advice…
If you are going to ask for help, actually read and follow the directions that were given to you.
You were being fused by two people that are very knowledgeable of the system. The other guy helping you, he is the one that wrote Alexa helper.
Just saying,a lot is done here because we want to help. But patience only goes so far.
But, I’m glad you got it working.
im not sure ibeastie has responded on if it is working yet or not
My bad… Your right @cino. That range was for @ibeastie, not you.
Guys thanks for all your help. I have it working now. The delete/re-add of app made the difference. Not sure why it would not show up. Once the helper app was available it was very easy to program.
Jason I’m interested in trying this without Alexa helper. Are you still planning to redo your write up?
I have to ask, did you actually read any of the posts that we sent you? Our did you just ramble through until it magically worked?
I’m not trying to be an ass, but seriously, this comment right here
This just spits in the eye of everyone willing to help.
Trust me, I’m not looking for any kind of gratitude or respect or glory…
I just get very annoyed when I try to help someone over and over and over and they thank the flying spaghetti monster when they accidentally flip the right switch.
Yes, I’m going to put it on the wiki.
Cool, thanks.
Curious on the setup as well. Let me know when you send out he details
I followed the steps the same way twice. Only after the removal and reinstall of the app did the Alexa helper show up. Sorry my comment didn’t live up to your standards. Yes I did read the instructions. You drilled it into my head. I said thanks because I truly do appreciate the responses and what I thought was patience. Not sure why on 2 occasions you got a little snippy and your last post was completely condescending. Sorry I even signed up to post. I’m out.
Honestly, if you would have done what you said you did…
Post 31 gave you a link on EXACTLY how to fix your problem. 5 days later you posted (directly beneath post 31) this…
And then in post 41 I posted the exact same link again.
and you posted this…
The part of your quote that is in bold is what really got to me. How could NOT possibly know why it just magically showed up? I mean really? You’ve been offered help for almost 3 weeks and then all of a sudden it just magically works? Really? And you wonder why I got ā€œsnippyā€.
It is crap like this that makes those that have been down the road and figured it out just up and quite trying to help. If you’re out, than you’re out. But at least your door works. I’m glad the flying spaghetti monster fixed it for you.
Btw, you could have had thing working flawlessly weeks ago.
@Ross @ibeastie
Here is a link to the write up on it. I have not put this on the Wiki yet, but I do plan to refine it and put it up there. I’m just waiting on access.
Let me know if you have questions.
Nice write up. I’m excited about getting this to work. I’ll try it tonight. Thanks!
did all of the above but alexa only responds when i say ON or OFF, when i say Open or Close it says ā€œIm not sure how to help you with thatā€ Any ideas as to what might be wrong?
Are you using the custom device handler for your door opener?
just alexa switch device handler as far as i know and can see. im not sure how to add custom device handler after completing your steps. i got it to work thru IFTTT using switch created with your steps. I can do Alexa, Trigger Open Garage and Close Garage. would love to know how to do this custom device handler. i read about it but im confused how it works with your steps
Follow this link to read about how to install custom device handlers and smartapps in the ST IDE.
i read that already, i know how to add it, i just need code for the device type:
DT1) Copy the code from the author. where do i copy code from? thats where i’m confused. Like i installed other custom device handlers for other things, but code was given or github repository.
