It pains me that the only real issue preventing me from going this way is one silly single gang box. We even spoke about putting the coffee pot on the other side of the cubby. But, the water and power lines are ran so that horse is gone.
If I was to go with a micro dimmer behind the wall switch, and a micro on/off in the shroud, what control would I loose at the wall switch?
Oh, and as much as I love my URC, I don’t want to think about asking my wife to control the fan or lights with it. If she CAN, great.
Two requirements. Normal control at the wall. Voice control.
I don’t disagree. However, once again your manly option leaves me in the doghouse with the one I call ‘dear’.
**I tried to respond but the UI said I had reached the maximum number of responses I could do in a day. So I guess this is it for me.
I’m on my computer in the car as we are driving back to KC from a thanksgiving get together. You have me laughing. My wife is asking what is going on - I’m not sure I can tell her about WAF.
I’ll keep researching and watching this thread - I appreciate any and all ideas.
bamarayne
23
Oh I solved that problem long ago… I gave her the remote!
At our house we use xAF, where X is anyone except The person who installed the device/rule. As in, “no one but you could ever figure out how to make this work! ” ( Very low xAF)
Need photos - but is it possible to move to another wall? Or move the fan switch to another?
I’d be surprised if you use the fan switch itself after ST/Echo or whatever,
I have no problem with the existing ones in 2 rooms - but my bedroom needs a redo. It will need changed to a 2-gang and run some wires. They all now have the old style rf fan controls - work but no st and I hate the dimmer set up.
Just don’t settle now, for something you will always regret.
I only skimmed the replies, but had not seen putting just the fan control in the single gang box on the wall. Then just use smart bulbs in the recessed cans. Either Hue BR30 or the Osram 5/6 can lights depending on what style recessed lighting you are using. Either will work with Alexa ( well if you want to change colors by voice you need to play a bit with virtual switches, or use AskAlexa )
If you are debating moving an Echo, I’d suggest grabbing another one ( or 2,) while they are on sale this weekend
As an update to anyone searching and finding this: It’s 12/29/16. I did go ahead and take the plunge to a Samsung ST hub, the Amazon DOT and a couple of plug in modules for our bedside lamps. I also installed a Harmony Elite Remote/Hub. The ceiling fan and in ceiling light fixtures are controlled by a “dumb” single gang switch with motor speed and dimming capabilities.
The plug in dimmers give us control of each of our lamps - by voice - both on and off. Plus, I have them set in a group so so they can be controlled together. This gives the wife the ability to say: “Alexa, turn my lamp on”. “Alexa, turn my lamp off”. “Alexa dim my lamp to xx”. She can do the same with mine, or she can turn them both on/off with “Alexa turn the bedroom lights on/off”
The good news? She. Loves. This.
So, there still seems to be no solution for my ceiling fan, in-ceiling lights. But, what I’d like to do is put a controller in the fan shroud. I’ll give up control at the wall if there is something that can control on/off/speed via voice/smartphone. But, alas, I don’t see anything that does even THAT. Short of putting a smart wall switch in the ceiling fan (ha!) is there a module that will do this?
Off Topic: The Harmony Elite/Hub work great. I’m not a fan of the limited customization of the software (compared to the URC software), but voice control is much more useful that I thought. Being able to change channel to any of my favorites is pretty cool. No hunting for the remote - “Alexa, turn to Fox News”. Nice.
If there is a module that can control fan speed, I have not found it yet. You have a couple that can handle on/off simple enough. Amazon.com . With it you can turn the fan and or lights on/off, but still have to use the pull chain to control fan speed.
