No way to know until you open it up and look at the actual wiring. There are at least 5, and probably more like 8, different ways to wire a 3 way. It all depends on exactly what is where.
In particular, these models need a neutral wire.
Screw Terminal installation; requires wiring connections for Line (Hot), Load, Neutral and Ground. Traveler wire required for multi pole installation
