Hi all,
Im wondering if anybody has already created a smartapp / device type for the neptune apex? its only external interface is a read-only XML. In theory, I would like to be able o take an action based on if an outlet / probe is a value or state.
If nobody has created an existing smartapp, does anybody have thoughts as to how I could approach creating one for a scenario as this?
An example of the xml is below
<status software="4.52_5A17" hardware="1.0"> <hostname>apex</hostname> <serial>redacted</serial> <timezone>-6.00</timezone> <date>09/12/2017 13:18:24</date> <power> <failed>07/26/2017 14:14:10</failed> <restored>none</restored> </power> <probes> <probe> <name>Tmp</name> <value>78.5</value> <type>Temp</type> </probe> <probe> <name>pH_tan</name> <value>8.13</value> <type>pH</type> </probe> <probe> <name>dTemp</name> <value>79.0</value> <type>Temp</type> </probe> <probe> <name>Condx12</name> <value>0.0</value> <type>Cond</type> </probe> </probes> <outlets> <outlet> <name>VarSpd1_I1</name> <outputID>0</outputID> <state>1_SPD</state> <deviceID>base_Var1</deviceID> </outlet>
